Central Vac Venting - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 11:49 PM   #1
central vac venting
I have recently purchased an older home with an installed central vac system. The system currently exhausts directly from the machine into the basement. The closest option is to pipe the exhaust into the sewer system fairly close to the main line. Is this a good idea, or are there potential issues with doing this? thanks
albertacowboy is offline   Reply With Quote
Old 05-19-2014, 01:37 AM   #2
Rewards Points: 332
Don't vent it to the sewer line. If the filter is installed properly, there's no issue venting into the basement. If you want to vent it outside though, you can run PVC between the floor joists and out the wall.
Sent from my SM-N900T using Tapatalk
sgip2000 is offline   Reply With Quote
The Following User Says Thank You to sgip2000 For This Useful Post:
albertacowboy (05-19-2014)
Old 06-02-2014, 08:26 PM   #3
Rewards Points: 494
Venting the central vac can be easier with any flex pipe. Rigid/smooth pipe not required, just same or greater size. May be tie into dryer vent?
Sewer gas will travel through the vac system.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
ben's plumbing (06-03-2014)
Old 06-03-2014, 07:03 PM   #4
thanks for the reply. I never thought of the gas... the direction of travel of the sewer pipe lead me to think that I wouldn't have to worry about liquid. I did run the pipe through the basement wall. I did a test on the exhuast with a white sock, and there was definitely dust coming out of it. It is an older, but likely high end Houver model.
Old 06-03-2014, 07:08 PM   #5
Rewards Points: 582
don't vent into sewer vent ...1 st against code..2nd against code..3 rd against code... also no way to prevent sewer gas from entering canister...just vent it outside or vent it through a hepa filter...
The Following User Says Thank You to ben's plumbing For This Useful Post:
albertacowboy (06-03-2014)
Tags
central vac , plumbing , venting
Ridge Cap Venting Issues - Poor Ventilation?? askeyb Roofing/Siding 16 03-29-2016 05:05 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 07:41 PM
Venting Water Heater near Central Air Unit rchrivera Plumbing 5 03-17-2010 12:03 AM
Attic venting in Central Texas radtek General DIY Discussions 7 06-10-2009 02:17 PM
