Cement Board Over Brick Fireplace - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-20-2008, 10:45 PM   #1
Question
cement board over brick fireplace
Hi,
We are doing renos on our 1957 house and part of that is a fresh look for the fireplace. The original bricks are solid but look rough. So, we decided to put these tiny tiles over them. The tile installers say the bricks are too rough for the tiles to go on flat. They require that we put up cement board over the brick and they will apply the tiles to that.
How can I mount the cement board to the brick and mortar with enough strength to carry the weight of stone tile? Do I just screw the board down with some concrete anchors? Are certain kinds [ie tapcons?] better for this kind of thing?
2 pics attached
Thanks,
Brian
cement board over brick fireplace-img_8412.jpg   cement board over brick fireplace-img_8414.jpg
wawrow is offline   Reply With Quote
Old 11-21-2008, 05:46 AM   #2
Rewards Points: 5,336
This is tile prep that the tile guys should be doing as part of the job. That aside, this is a two step process. I would thinset the cement board to the brick and then tapcon the cementboard to the surface. This would be the same procedure as applying it to the floor.
Ron
Old 11-21-2008, 10:21 AM   #3
Rewards Points: 1,220
I would just do a scratch coat over it to smooth it out using regular mortar and a bonding agent.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is online now   Reply With Quote
Tags
brick , cement board , fireplace
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 11:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
