Ceiling Tiles - Cutting Recessed Ones? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-04-2007, 08:06 AM   #1
Ceiling Tiles - cutting recessed ones?
Hello
This maybe a stupid question but just how does one make those recessed ceiling tiles look factory when they are cut? we're installing suspended tiles on a direct grid system like Ceiling Max. We've seen some we like but have that recessed edge. I just didn't know if it was allot of work since I'll have to do several (about 40).
Kenny J
Stargazer is offline   Reply With Quote
Old 12-04-2007, 08:52 AM   #2
Rewards Points: 150
Straight from CeilingMax site:
10. How do I cut border panels if I'm using a revealed tile?
On a revealed panel, you will notice a 1/4-inch lip around the edge of the tile. If you need to cut a border panel, you first need to cut the panel down to the border size. To do this measure from the wall to the front edge of the cross tee. Then, lay the tile in the grid. Score the face of the tile along the edge of the wall bracket and pull the tile out of the grid. Line up a strait edge on the scored line you created on the face of the tile. Run a utility knife along the strait edge cutting into the tile. Then cut into the side of the panel dropping out the corner of the tile.
So, basically, you cut the lip yourself. With a sharp utility knife and a straightedge, should not be hard.
scorrpio is offline   Reply With Quote
Old 12-04-2007, 10:53 AM   #3
Rewards Points: 12
I did this for five years on commercial/residential jobs and actually worked for the same company that invented ceiling max and there instructions are right on. One thing is you don't need a straight edge when cutting, after scoring the tile to the wall angle(which might not be straight) you can just use a utility knife to follow the traced line. Good luck and it's really not that hard once you get the hang of it.
ponch37300 is offline   Reply With Quote
Old 12-04-2007, 10:55 AM   #4
Rewards Points: 5,336
They sell a tool for this cut. I think HD had them in the aisle with the tiles. You set the depth and slide it along the tile for both cuts. I found it a handy tool to have for the job.
Ron
Old 05-13-2012, 10:10 AM   #5
Cutting the rabbet in recessed ceiling tile
To Ron6519
I have 2 people and now you telling me there is a tool for this. Our local HD and Lowes have no idea what I'm talking about. I can certainly cut these with a utility knife but in order to make them look like the others the cut would have to be on a slight bevel and that will be difficult to do the same way consistently. Do you have a name for the tool? Maybe a pic?
wolfem is offline   Reply With Quote
Old 05-13-2012, 10:27 AM   #6
Rewards Points: 150
They will be found at architectural/building supply houses that specialize in the sale of commercial rated tiles. The "shadowline" tool is just a wood block with one edge rabetted out and a utilty blade screwed on to it. It could be made at home.
Jeeps is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
New Basement Ceiling with Ceiling Tiles crgauth Remodeling 2 11-03-2007 09:24 AM
Recessed Lighting For Ceiling Tiles?'s Stargazer Remodeling 6 09-04-2007 10:42 AM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 05:46 AM
? asbestos ceiling tiles willyoldschool Building & Construction 2 11-07-2006 11:47 AM
