Ceiling Screw Hooks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-06-2007, 08:11 PM   #1
Ceiling Screw Hooks
Hi,
What is the proper way to install these hooks?
I'm using them to suspend a <10 pound airplane. Do I pre-drill a hole or what?
I want to make sure they hold. I think the ceiling is concrete.
Thank You very much!
Zoom is offline   Reply With Quote
Old 12-06-2007, 10:08 PM   #2
If it's concrete, you must use a plastic masonry anchor - not the same as those for drywall - that will accept the same size screw as that of the hook you're using. The proper type of anchor for this is a Red Dog (I believe that's the brand name) #8 (3/16" hole) or #12 (1/4" or 5/16" hole) and you can find them at any HD. The screw threads cut through the collar of the anchor, bulge out the three section side and then engage the anchor's end deep in the hole. As you continue to tighten, the end and the three sides begins to spiral and knot up, making the anchor and screw extremely secure in the drilled hole.
Edit: The brand name I was referring to is Red Head, not Red Dog.
End Grain is offline   Reply With Quote
Old 12-06-2007, 11:18 PM   #3
Thanks for the answer.
That's exactly what I was looking for.
Old 12-08-2007, 11:06 PM   #4
Mod / ArchiBuilder
Cole's Avatar
You think the ceiling is concrete, have you actually inspected to make sure?
Cole is offline   Reply With Quote
Ceiling fan - Downrod won't screw in all the way tima2381 Electrical 8 05-02-2012 03:57 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Screw in Track Lighting Bar Popping Out SueC456 General DIY Discussions 5 03-13-2007 08:24 AM
