Ceiling Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-08-2008, 05:44 PM   #1
yo_paully's Avatar
Send a message via MSN to yo_paully Send a message via Skype™ to yo_paully
Question
Ceiling problem
Hello,
I am helping my parents try to figure out an issue they have with their ceiling. Here's the problem: It's a seventeen year old home, one floor plus a finished basement, they are the original owners. The ceiling, which is drywall, has markings where the studs run. The markings are the length of the entire floor. The ceiling has been painted twice, once by the builder and once again by a professional painter. The markings began to show up about ten years ago, the ceiling was painted about seven years ago and the markings came back about a year later. Any idea what may be causing the markings?
Thanks.
yo_paully is offline   Reply With Quote
Old 08-09-2008, 08:44 AM   #2
What type of markings are you referring to? Is it a stain,streak,crack or taping job? Pics would really help the pro's on this site.
JohnJak is offline   Reply With Quote
Old 08-09-2008, 08:56 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
could the marks that you are describing resemble soot! is there a fireplace or oil fired burner in the house. I have seen where if the boiler isn't running properly. you will see black sooty type of marks on the ceiling where the beams are located. this could also happen when cooking if the stove or oven isn't vented or is not exhausted to the outside when being used.
Just a suggestion on a probable cause being there is no photo. BOB
Old 08-09-2008, 09:03 AM   #4
ccarlisle's Avatar
Also, it may be a sign that condensation is happening, if the marks are exactly along the ceiling joists i.e about 16" oc apart, and run length to length. Let us know exactly where. How 'bout candles? use them?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-09-2008, 09:23 AM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 848
Pictures Please!
Sir MixAlot is offline   Reply With Quote
Old 08-11-2008, 11:57 AM   #6
yo_paully's Avatar
Thanks for the responses!
I've attached some photos for clarification.
Ceiling problem-ceiling001.jpg   Ceiling problem-ceiling002.jpg   Ceiling problem-ceiling003.jpg   Ceiling problem-ceiling004.jpg
Old 08-11-2008, 11:59 AM   #7
yo_paully's Avatar
buletbob: There isn't a wood-burning fireplace in the house, but there are two gas fireplaces, a gas stove, a gas laundry dryer and a gas furnace. All were installed and vented professionally. Thanks for the suggestion, we will double-check the venting.
Old 08-11-2008, 12:00 PM   #8
yo_paully's Avatar
ccarlisle: The marks appear to be exactly along the ceiling joists. The pictures above should clarify my description. Candles aren't used very often - they have five grandchildren and a dog running around the house
Old 08-11-2008, 05:10 PM   #9
ccarlisle's Avatar
That's thermal tracking, a condition of houses with dirty air, poor insulation and leaky walls. Comes from moist dirty air passing over the cooler drywall and depositing the dirt where the joists run. Solution is to check your gas burning appliances because that's where the dirt comes from, check the insluation and vapour barriers behind those walls, increase if called for, then washing the walls.
Without solving the condition first further coats of paint are a waste of time and $...
Old 08-11-2008, 06:10 PM   #10
Rewards Points: 848
I would guess condensation by looking @ the pitch of the ceiling. How is your roof vented? How much space between your roof decking and your drywall ceiling?
Old 08-27-2008, 04:31 PM   #11
Advice worth 2 cents!
Rewards Points: 150
CCarlisle is right on the money.
See that ceiling fan? That's a sign of someone trying to cut corners on heating! (especially on such a low ceiling). I'm probably being a jerk but, that house needs better insulation in the attic, more ventilation and I really hope the builder put in the proper vapor barrier.
-pete
---pete
HandyPete is offline   Reply With Quote
Old 08-27-2008, 06:40 PM   #12
General Contractor
joasis's Avatar
I agree as well....more insulation.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 08-28-2008, 07:09 AM   #13
Mold!! Let's kill it!
Rewards Points: 2,012
I agree with the posts above. The ceiling joists (or bottom cord of the trusses) are acting like radiator fins and allowing the drywall to cool just a bit where they are in contact. Since the drywall is backed by several inches of wood, the moisture can't disipate in those areas as well either. Get some insulation above them. The wood above and the strips of drywall will warm to the same temperature as the rest of the ceiling. Repaint with a stain blocker like Kilz and that should eliminate the stripes. If there is no vapor retarder directly above the drywall, it would probably be a good idea to coat the ceiling with a low permiability paint. A good paint store can provide it.
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
My ceiling fan wiring problem jkrodger Electrical 9 08-13-2007 04:51 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 10:55 AM
