I'm moving into a new apartment and I'm trying to find a place to mount a pull-up bar (doorframes aren't conducive seeing as they're lacking trim that will support that type of bar). I know I can get one that will attack to studs in the wall, but before I go that route I want to see if there's a place I can mount one to the ceiling.
Below are some pictures of the apartment. As you can see, the ceiling as a few different heights, with the drop-down parts concealing the duct-work for the central air (at least that's what I'm assuming they're there for). Along the edge of all those ceiling drops I assume there is a 2x4 or something along that line.
The obvious concern is if whatever framing in there would support a bar + my weight (170lbs or so).
The higher portions of the ceiling are a bit too high up to put a bar, which is why I'm considering these spots at the moment
