Ceiling Heat - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 01:56 PM   #1
ceiling heat
I need to hang a pot rack from the ceiling but I have electric ceiling heat... how do I know where to drill in order to hang the rack?
kklockner is offline   Reply With Quote
Old 06-25-2010, 11:24 PM   #2
Rewards Points: 6,652
Hard to tell, unless you use x-ray glasses.
The Following User Says Thank You to gregzoll For This Useful Post:
kklockner (06-28-2010)
Old 06-26-2010, 06:31 AM   #3
Rewards Points: 5,336
If the electric heat is a mesh product, you won't be able to without damaging the heating element.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 06-28-2010, 07:57 PM   #4
Turn on the heat and then take a photo of the ceiling with an infrared camera.
Before taking the photo make a grid with aluminum tape as a reference point.
Old 06-28-2010, 10:03 PM   #5
Thank you!
I appreciate the feedback. A smart solution wildie.
I went ahead a pulled back the sheeting over the ceiling joists and located them visually, No chance of mistakes that way.. Hot up there but worth it.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Heat vents near ceiling Cossack General DIY Discussions 3 04-13-2008 08:31 AM
