Ceiling Hairline Cracks And New Paint - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 05:08 PM   #1
Slowgo Newbie
Ceiling hairline Cracks and New Paint
We are having our house painted and our ceiling painted and there are some hairline cracks and actually some previous damage and new damage to the ceiling that requires touch up work. The damage are mostly hairline cracks and some seam work bumps that I think needs to just be smoothed out etc.
I have been told by the painter that he can fill and feather the cracks out, and a drywaller told me it was a much bigger job and he would have to do all of these things. It is asthetic only and the paint job on the ceiling is poor, not even which adds to the problem.
The ceiling seam tape only tested positive for asbestos, so we have had all sorts of advice on that, and do want to keep the repairs minimal.
I need advice on what will and won't work, and also what is the best ceiling paint to hide flaws.
Any advice is greatly appreciated.
sw8689 is offline   Reply With Quote
Old 11-08-2009, 07:15 PM   #2
Remodeling Contractor
apply a textured coating if you do not want to fix these flaws correctly.
Old 11-09-2009, 12:15 PM   #3
Slowgo Newbie
Ceiling
Thanks for your reply.
I do want to do it correctly, just not pulling it apart. I don't think Texture on this part would work as the house is huge and open to the other rooms. I think maybe, I think it's worse than it is and maybe now that I found a few cracks and buckles i see them all. I am wondering if a good filling and sanding and good paint will work and if others have done that.
Old 11-09-2009, 01:16 PM   #4
to fix cracks you first open them up more. This removes the loose material you do not now see and allows the patching compound room to have something to stick to. Then fill with compound. let dry. sand. fill again as needed. (it shrinks) Prime with PVA primer. Paint two coats. You will be fine. Avoid cheap paints.
Old 11-09-2009, 01:32 PM   #5
Slowgo Newbie
Ok, thank you.
There are also a few bumps where the drywal seams are, long ridges, not too bad, but would I just sand those down a bit?
We are using Benjamin moore on the rest of the house and their ceiling paint for the ceiling, is this what you would recommend?
Old 11-09-2009, 02:41 PM   #6
yes that is a good paint. the bumps may have to be cut out and re-taped. That is if the problem is a bubble behind the tape. if it is a true bump, hammer it in and fill with compound. If it is a small ridge, maybe sanding will do it. But sanding after someone painted will get you nowhere.
Old 11-09-2009, 03:53 PM   #7
Drywall contractor
Rewards Points: 1,070
If it comes down to who does the work, I'd let a drywall contractor do the drywall repair and the painter do the painting. Except for a few cases, I haven't seen either trade that does well at the others' job. The painter can likely do minor touch-up proficiently, but actually running joints and major patches should be done by a drywall professional......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-10-2009, 01:55 PM   #8
Slowgo Newbie
Thank you bj, good advice, I will have a drywaller here and consult with him/her. There are 3 ridges and they are not that noticeable, but if smoothed out will be virtually undetectable with good paint I think.
Old 11-10-2009, 02:26 PM   #9
Any flaws in the drywall will be enhanced not hidden by the paint. A flat paint will show less, but is not washable.
Old 11-11-2009, 12:43 PM   #10
Slowgo Newbie
Oh, I thought a couple coats of good ultra flat ceiling paint would clean things up, that's what I was told by a number of folks. This ceiling is feeling doomed and it's not even that bad.
