Ceiling In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 06:40 PM   #1
Rewards Points: 99
ceiling in garage
Is it safe to hang up kayaks from garage ceiling to what appears to be metal rafters/studs. The metal is thin and seems to be nailed to drywall and wood beams. I have actually already put up the kayaks and it seems secure, almost put all my weight on it as well. Any feedback would be truly appreciated. Just want to be sure kayaks won't come down crashing into cars.
er78mph is online now   Reply With Quote
Old 04-12-2012, 06:55 PM   #2
Rewards Points: 6,652
Not really, depending on the weight of the kayaks. You would be better to build a frame up in the attic space out of 2x8 or 2x10 as a sister joist, so that you can secure them on the wood joists.
Old 04-12-2012, 10:37 PM   #3
Framing Contractor
You said garage ceiling.
Now you say metal rafters/studs. What are you talking about? A ceiling or rafters?
You ask this after you do it??
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-12-2012, 11:10 PM   #4
Rewards Points: 1,092
Pls describe more accurately what is going on. "Metal is thin and appears to be nailed to drywall and wood beams..." Is this a suspended ceiling or something? I'm confused. That said, if you and the kayak have been hanging on it, it may well have passed the "gross overload" test and be fine. MAY have....
Old 04-12-2012, 11:12 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Time will tell......
sublime2 is offline   Reply With Quote
Old 04-12-2012, 11:20 PM   #6
Rewards Points: 99
garage ceiling
Joe,
Sorry, wrote msg all at one time and I am talking about the ceiling. Instead of finding wood with stud finder I am finding metal. I hooked up two kayaks to the metal and they seem to be okay but would like to know what the metal is. Thank-you!!
Old 04-12-2012, 11:34 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Joe,
It would appear they used metal studs to frame your garage ceiling.
If you don't have access to the framing in the ceiling I would use numerous hooks across the length of the kayak to dristribute the weight.
Metal studs are not reliable for carrying a lot of weight by them selves.
Old 04-12-2012, 11:39 PM   #8
Rewards Points: 99
Jklingel,
Sorry for confusion. I used a stud finder on garage ceiling and found metal instead of wood. I don't know why metal is up there and simply want to know if its safe? Kayaks have been up for 3 days.
Old 04-12-2012, 11:49 PM   #9
If in doubt, poke a hole in the sheetrock big enough for your head w/ a headlamp attached. It's easy to repair. If you have metal trusses, or very large studs, you are probably ok. However, first find out exactly WTH is up there, then see someone versed w/ them; perhaps an online shop will provide spans and loads, and you can take it from there.
Vapor barrier in garage ceiling? titaniumring Drywall & Plaster 14 10-20-2011 08:14 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 12:40 AM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 02:46 PM
