-   -   ceiling in garage (http://www.diychatroom.com/f2/ceiling-garage-140115/)
er78mph 04-12-2012 07:40 PM
ceiling in garage
Is it safe to hang up kayaks from garage ceiling to what appears to be metal rafters/studs. The metal is thin and seems to be nailed to drywall and wood beams. I have actually already put up the kayaks and it seems secure, almost put all my weight on it as well. Any feedback would be truly appreciated. Just want to be sure kayaks won't come down crashing into cars.
gregzoll 04-12-2012 07:55 PM
Not really, depending on the weight of the kayaks. You would be better to build a frame up in the attic space out of 2x8 or 2x10 as a sister joist, so that you can secure them on the wood joists.
Joe Carola 04-12-2012 11:37 PM
You said garage ceiling.
Now you say metal rafters/studs. What are you talking about? A ceiling or rafters?
You ask this after you do it??
jklingel 04-13-2012 12:10 AM
Pls describe more accurately what is going on. "Metal is thin and appears to be nailed to drywall and wood beams..." Is this a suspended ceiling or something? I'm confused. That said, if you and the kayak have been hanging on it, it may well have passed the "gross overload" test and be fine. MAY have....
sublime2 04-13-2012 12:12 AM
Time will tell......
er78mph 04-13-2012 12:20 AM
garage ceiling
Joe,
Sorry, wrote msg all at one time and I am talking about the ceiling. Instead of finding wood with stud finder I am finding metal. I hooked up two kayaks to the metal and they seem to be okay but would like to know what the metal is. Thank-you!!
sublime2 04-13-2012 12:34 AM
Joe,
It would appear they used metal studs to frame your garage ceiling.
If you don't have access to the framing in the ceiling I would use numerous hooks across the length of the kayak to dristribute the weight.
Metal studs are not reliable for carrying a lot of weight by them selves.
er78mph 04-13-2012 12:39 AM
Jklingel,
Sorry for confusion. I used a stud finder on garage ceiling and found metal instead of wood. I don't know why metal is up there and simply want to know if its safe? Kayaks have been up for 3 days.
jklingel 04-13-2012 12:49 AM
If in doubt, poke a hole in the sheetrock big enough for your head w/ a headlamp attached. It's easy to repair. If you have metal trusses, or very large studs, you are probably ok. However, first find out exactly WTH is up there, then see someone versed w/ them; perhaps an online shop will provide spans and loads, and you can take it from there.
