Ceiling Fan Too Big?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 06:01 PM   #1
Ceiling fan too big??
I installed a ceiling fan of 42' diameter in my master bath. The fan was new in box given to me by my parents who were not going to use it. It just feels to not move any air. Is it too big? The room size is 12 ft by 5 ft. thanks in advance
D-rock is offline   Reply With Quote
Old 08-17-2011, 06:14 PM   #2
Code05's Avatar
Rewards Points: 1,104
Is any part, including blades, of the fan within 3 feet of a tub or shower?
Code05 is offline   Reply With Quote
Old 08-17-2011, 06:41 PM   #3
the Musigician
DangerMouse's Avatar
Reverse the blade direction and see if that helps.
DM
Old 08-17-2011, 07:18 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
DM
yup, might be a little slide switch on the fan body. slide it over, put it on high and see if you notice any differance
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-18-2011, 06:20 AM   #5
I installed a 42-44" fan in the shower/toilet room of the master bath. The room is a little smaller than the one described by the OP. This was the largest fan I could fit into the space and it is close to the ceiling. On high, it moves enough air to barely move the towels on the rack directly below it. It moves far less air than the 52" fans I have in other rooms, but it does help dry out the towels and shower to reduce humidity in the room.
David
Jessidog is offline   Reply With Quote
Old 08-18-2011, 03:39 PM   #6
Yes, about 18-20 inches
Old 08-18-2011, 03:41 PM   #7
I flipped the directional switch, now that air feels somewhat better, just feel it on the walls more then the center of the room.
So....if i was to install a 29-30 inch fan, will I get more air flow??
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
