Ceiling Fan Support Bracket - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 02:18 PM   #1
Rewards Points: 79
I want to install a ceiling fan and ceiling box. The joist spacing is 12" o.c.
I don't have access from above.
All the adjustable hangers I have seen are for 16 to 24" joist spacing. I'd like to mount the support through the 4" hole I will need to put into the drywall.
Any suggestions?
RalphPeters is offline   Reply With Quote
Old 12-17-2012, 02:25 PM   #2
Rewards Points: 12,816
Any way to scoot it over so it would be under the joist?
http://www.bing.com/shopping/4-1-16i...M=EGCA&lppc=16
Old 12-17-2012, 04:14 PM   #3
Rewards Points: 79
Yes I could move it under the joist, it just wouldn't be centered in the room. That sounds like the easiest option.
Not sure what you're link is showing.
Old 12-17-2012, 05:14 PM   #4
Rewards Points: 558
You can toenail in a piece of 2X4 between the two joists and fasten one of the other boxes to it or you can take the straps apart and cut the inside ends of the straps so it would fit inside you 12 space.
epson is offline   Reply With Quote
Old 12-17-2012, 06:21 PM   #5
Any suggestions?
if you are determimed to have it centered consider screwing a 1 x 4 to the studs and then attach your elect box. See if you can locate a large enough rosetta (? terminlogy) that you can get at any home inprovement store to cover the board. Don't know if it is deep enough to cover the 3/4 inch board. I have see them and they appear approx 8 to 12 inch diameters. May also check the net for larger ones. if you find a rosetta large enough you could then cut out the sheet rock and the thickness would not be an issue.
doyleslaughter is offline   Reply With Quote
Old 12-17-2012, 07:39 PM   #6
Rewards Points: 79
Thanks everyone
I'm going to fasten it directly to the joist
Old 12-17-2012, 09:14 PM   #7
Rewards Points: 140
or if its drywall. just cut out a 12" square piece. screw in a 2x6. and patch the hole.
Fix'n it is offline   Reply With Quote
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
overhead service support bracket ponch37300 Electrical 6 05-22-2009 05:23 PM
