Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-05-2012, 10:19 PM   #1
Ceiling fan issue
I have a Harbor Breeze ceiling fan
44" Weston 11 Oil Rubbed Bronzed
Model No. F1-20RB
It was put in a couple of years ago when my kitchen was renovated. I also had a hunter remote control installed on the fan. For the past few months or so the fan only operates at low speeds whether it's on high, med, or low. Does anyone have a clue what the problem is? Is the motor going? Any adjustments need to be made?
Keith vent is offline   Reply With Quote
Old 09-01-2012, 06:23 PM   #2
Bombastic Idiot
notmrjohn's Avatar
Ceiling fan issue
You threw me with that "motor going," of course it is, the fans turning. Could be going or gone if motor is cause. Could be the remote, don't know how you check that. Could just be loose connections. If there is no light kit, you can take bottom cover off and check. Turn on fan power at wall switch, turn off circuit breaker, did fan stop? good. Take out wall switch and gently tug on wires at wire nuts and other connections take cover off fan, gently tug on those wires and connections. Re-connect and tighten if needed. Try to stuff the wires back into that lil compartment and replace cover. If it is not that you may have burned out wiring in motor. Depending on model it may not be worth repairing, if you could find someone to do it.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
Keith vent (09-01-2012)
Old 09-01-2012, 07:11 PM   #3
Smile
Ceiling fan issue
The ceiling fan issue has bern fixed. I took off the light kit and found a very short chain, used for controlling fan speed. I added additional chains and problem has been fixed...lol.
Old 09-02-2012, 05:13 PM   #4
Bombastic Idiot
notmrjohn's Avatar
Ceiling fan issue
DOH! i keep starting at the wrong end, forgetting about the simple stuff. Mebbee I can take solace in thinking my suggestion to open the fan lead you to finding the chain. But you've had it a couple of years and the problem only started a couple of months ago? Has somebody been pulling that chain or are you pulling mine?
Old 09-04-2012, 12:54 AM   #5
awd
Ceiling fan issue
I have similar problem except, the fan's switch have 3 speed (1 2 and 3). but only 2 speed. (2 and 3 setting, fan turn the same speed). I have tried pulling the fan chain (other then the stoppping the fan, it didn;t change anything)?
Can it be the fan comes only in 2 speed? if not, how can I get the 3th speed?
thanks
awd
awd is offline   Reply With Quote
Old 09-04-2012, 09:58 PM   #6
Bombastic Idiot
notmrjohn's Avatar
Ceiling fan issue
awd, I can't imagine a situation where you'd get two speeds from a 3 speed wall but only on/off at chain. Unless you have some sort of 2 speed fan/switch set where speed is controlled only by wall, is it the original wall switch? Do you get the "only on-off" at chain with all wall settings?
The chain switch turns on one of three wires, each wire has a different resistance that only lets a certain amount of electricity go to mot.or, low the least amount, high the most, so fan runs at different speeds. Usually a 3 speed fan is set on high with chain, then wall switch controls speed. If chain is set on 2 then fan won't run even if wall says 3. if that was your problem, you wouldn't get just on-off. If your 3 was burned out at fan, you'd get off-low-medium-off-off-low by pulling chain. If medium is burned at fan you get off-low-off-high-off. If low is burned you get off-off-medium-high-off. Some fans work in reverse order first pull is high then on down.
Some wall switches work the same way, with 3 seperate (internal) wires, especially 3 position ones. If one of those speeds was shot and chain is on, you'd get the similar sequences as B4. When you set the shot speed fan would be off.
Some swiches are "additive", so to speak, On 1, electricity goes thru only one wire, at 2 thru two wires, 3 three wires. One of the wires could be shot, power only goes thru 2 wires, giving you only two speeds. You can't see the wires, they're inside.
Some fans use a rheostat, a switch that controls amount of electricity to one wire, usually these switches have a knob that turns or a slider with stops, giving you variable, unset speeds. I don't know if there are 3 position rheostat switches, there probably are. The higher "end" of a rheostat can stop working, The fan wiil work at all speeds up to the bad part and keep working but no faster.
Ya know what? By typing that i realized a situation where you could get different speeds from wall and only on-off at chain. You have a one speed fan controlled at the wall. You need a new wall control. Just a 1 2 3 type. Easy to install http://www.ehow.com/how_7556761_wire...an-switch.html . All I would add to those instructions is to lokk on back of new switch where black wires come out, one should be labeled "Live", "hot" "power", the other one "load" "fan" "light" or similar. B4 disconnecting wires from old switch and see which wire from house is connected to "Live" and wrap a piece of tape around it so you can connect to proper lead in new one.
Dohhhhhhhh! Its late, my brain done up and left me for some other skull. I couldn't think it thru. Well, now you now how ceiling fan switches work. Next question I answer is " Why doesn't my fan and lights work? I'd write the power co. but only place I can find the address is on electric bill and I always throw those away unopened." I'll answer with long explanation of how electricity works.
Old 09-04-2012, 10:41 PM   #7
awd
Ceiling fan issue
thanks, NotMrjohn.... IT will take me awhile to "digest" all this, WIll provide update later,,,,
thanks,
awd
ceiling fan light issue after replacing electrical panel texan206 Electrical 3 04-22-2012 12:33 AM
Historical Interior Ceiling Issue nscott5 Building & Construction 1 08-28-2011 03:13 PM
Ceiling Old&New Paint Issue tasmisr Painting 5 07-19-2011 11:19 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
ceiling fan dimmer switch issue irich Electrical 4 02-10-2008 11:23 PM
