Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-30-2005, 01:04 PM   #1
Question
cedar paneling
I have a new bedroom closet I wish to add cedar paneling. I purchased the paneling in 4' lengths by 4" wide boards. I have liquid nail and finishing nails.
Is there a "simple" way to install this? To keep this simple I will be applying in a vertical, up and down pattern, nothing complicated.
The closet is 8' wide by 7' high.
One board need to be cut approximately 18" added to the uncut board to fit floor to ceiling.
Is there a trick?
patp is offline   Reply With Quote
Old 03-30-2005, 07:40 PM   #2
Contractor
cedar paneling
Is it Brown's SuperCedar? Just curious. What is the ceiling height?
Teetorbilt is offline   Reply With Quote
Old 03-31-2005, 12:01 PM   #3
Carpenter
DecksEtc's Avatar
cedar paneling
If your ceiling height is 7' then by my calculations you'll have a 36" piece at the top if your paneling pieces are 4' long.
One suggestion for you is to have all the 4' boards at the bottom, put all the top 3' long boards in the same pattern above them and then cover over the seam with a piece of cedar trim.
Are the pieces you purchased tongue & groove? If so, you can nail it to the wall at the "tongue" and have the nails virtually hidden.
DecksEtc is offline   Reply With Quote
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 11:27 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing 5 10-12-2006 06:22 PM
new cedar roof and zinc advice garym112 Roofing 1 01-18-2006 07:25 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
