Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-04-2006, 10:01 AM   #1
Caulking to a tiled wall
My wife owns a restaurant and has a display case that weighs about 5 pounds or a little more. This case must hang on a tiled wall but I hate to drill holes into the tile because this will be the second time I've had to move it leaving holes in the tile. I tried using some 2-inch wide velcro strips but the tape eventually pulled away from the wall.
After caulking a bathroom sink, I thought about the fact that silicone caulk sticks pretty good to tile. I was wondering how stupid of me it would be to caulk the velcro, or the case itself, onto the wall?
drhowarddrfine is offline   Reply With Quote
Old 10-04-2006, 10:11 AM   #2
General Contractor
Why do you have to keep moving it?
Hammatime is offline   Reply With Quote
Old 10-04-2006, 10:34 AM   #3
New equipment was moved in front of it.
Old 10-04-2006, 10:49 AM   #4
They're all fixer-uppers
J187's Avatar
Liquid nails actually bonds surprising well to tile despite saying on the tube not designed for ceramics. But I've used it to hang trim around a heat register that I could not for the life of me find an appropriate outside diameter for. So, I trimed the register out with wood molding and used the LN to hold it on. Its not 5lbs, but you couldn't pull from the wall without a prying tool.....
J187 is offline   Reply With Quote
Old 10-04-2006, 11:00 AM   #5
you could use PL Premium... it woun't move.
mhervy is offline   Reply With Quote
Old 10-04-2006, 11:57 AM   #6
What is PL Premium?
Old 10-04-2006, 04:26 PM   #7
PL is a construction ashesive, comes in a caulking tube, you can get it at any home building centre, Home Deopt etc.
More On This Topic
Materials for Painting
Materials for Painting by Expert Village
Hello my name is Grady Johnson. I'm a professional painter and today I represent Expert Village.com Now I'm going to talk a little bit about the materials we need for interior and exterior painting. Now whenever we're painting we know the first thing we... Read More »
Caulking any gaps before beginning a paint job on the interior of your home will ensure a nice, even finish. There are often cracks where trim meets walls and windows and they will need an application of caulk. Follow these steps to apply caulk on... Read More »
Hello! My name is Grady Johnson and I am a professional painter and today I am representing expertvillage.com. Now I would like to talk about the materials we are going to need for the exterior wall painting today. To start with we are going to have to... Read More »
O.k., so now that we have all of our tools in place, we're going to go over some of the materials we'll need, including paint, for painting our kitchen. Alright, first, this is the caulking, it comes in a variety of different colors and we want to have... Read More »
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The last full panel course is cut and installed. Vented top row flashing is then cut and installed as wall flashing. In snow climates rich foam... Read More »
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
