Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-15-2011, 12:07 PM   #1
Question
Caulking Nightmare or...
I just began re-caulking my bathroom. I haven't gotten very far...just now removing old caulk (silicone) with a razor blade. I don't know a whole lot about types of materials things are made of, but I will try my best to explain....
My best guess is the tub is coated steel (i can scrub the heck out of it and it doesnt ever scratch). Surrounding the tub is a plastic(?) liner that goes up to the shower head, which is boardered by painted wood framing. Here is my dilemma (or not?)...
As I was cutting the old caulking away from the joint (between the top of the tub and the plastic liner), I can see that it is really wet and moldy behind the liner. Is there an easy fix to this or have I just created 100x more work for myself?
Is it typical for it to be just the wall (drywall) behind this liner? I ask because I have always had tile. This liner seems to be a bit of a pain in the bum, and it doesn't help that the last caulking job was seemingly done by a child
Any help or advice would be greatly appreciated! Also, this is my first post beyond my intro, so if I am missing any info or need to add pics of this mess, let me know. Thanks!!
tmay is offline   Reply With Quote
Old 07-15-2011, 01:17 PM   #2
Not so new
12penny's Avatar
Well...maybe not 100x. For sure, if it were mine I'd remove the shower liner and further assess the damage. You certainly can't leave it that way.
12penny is offline   Reply With Quote
Old 07-15-2011, 01:23 PM   #3
Tileguy
Bud Cline's Avatar
No. Remove the plastic, clean substrate, if there is no real damage replace the plastic surround.
Old 07-15-2011, 02:00 PM   #4
Household Handyman
I also agree with removing the "tub surround", the plastic pieces, and assess the damage to whatever is under this surround material. There has also been a very detailed, and very good, post on this site as to how to properly "re-caulk" a bath area, or an area high in moisture. Try a search to find it.
Old 07-15-2011, 02:05 PM   #5
sdsester's Avatar
Whatever you do, do not use silicon to caulk again. You can use caulk with SOME silicon in it but silicone itself is not a good caulking material.
It is one of the things on my "work of the devil" list.
sdsester is offline   Reply With Quote
Old 07-15-2011, 02:59 PM   #6
Thurman- I have actually been following that exact post you are talking about, but ran into the mold problem. It is a great post...very informative
Old 07-15-2011, 03:04 PM   #7
Thanks for all the quick responses! The tub surround is in five pieces. I easily lifted one of the pieces away from the wall and it's....disgusting. I'm contemplating taking it down and tiling the area. We don't own this place so I will need to contact the owner. Thanks again
Old 07-15-2011, 05:45 PM   #8
Tileguy
Bud Cline's Avatar
i'm contemplating taking it down and tiling the area. We don't own this place so i will need to contact the owner.
hold on !!!
Old 07-16-2011, 06:48 AM   #9
paper hanger and painter
chrisn's Avatar
YES, it is
chrisn is online now   Reply With Quote
Tags
bathroom, bathtub, caulk, caulking, mold
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 06:25 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 06:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 09:33 AM
