Caulking Around Thru The Wall A/C - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 01:58 PM   #1
Rewards Points: 101
Not really sure what topic this would fit under so I threw it in the general category. I had replaced my thru the wall a/c last summer and never got to sealing up the outside since its on the 2nd floor and I needed a large extension ladder.
Finally got my hands on a ladder now I have a question. I was going to caulk it between the sleeve and the siding. However this sleeve is slightly smaller then the original. I had put in some 1x4's to build up the opening a bit. When I seal it from the outside can I caulk directly on top of the wood to seal the gap between the a/c sleeve and the siding? Or should I apply something else first?
jte1130 is offline   Reply With Quote
Old 04-22-2009, 05:42 PM   #2
Rewards Points: 5,336
If the gap is 1/4" or less, you can just caulk it. If it's larger, say 1/4"-3/8"use a backer rod to take up the space and caulk the backer rod. More then that would require something else. It would depend what it looks like.
If you did it correctly, the gap shouldn't be more then 1/4"
Backer rod is sold in the big box stores in the weather stripping aisle.
Ron
Old 04-23-2009, 10:55 AM   #3
Rewards Points: 101
There actually is no gap between the a/c and the built up box. What I'm worried about is on the outside of the house the 1x4 that I used to build up the box is now slightly exposed. Since the siding and flashing mathched the original hole there is now a slight exposure of the wood. I just was wondering if I could caulk over the wood.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
