Caulk That Washes Away? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 06:13 PM   #1
Caulk that washes away?
Relatively new homeowner here, and I'm hoping someone can help me with a caulking problem. I had to recaulk my shower, specifically the line where the tub meets the tile on the wall. I used DAP Kitchen and Bath caulk, and I *thought* I covered all the bases. I removed all the old caulk, used a bleach solution to clean up, dried, and then applied the caulk. I waited 24 hours before using the shower.
After a few days, I noticed that the caulk appears to be washing away. After a shower, I touched the bead and some caulk came away on my finger. What am I doing wrong? Is it the wrong product? Wrong application?
kapsberger is offline   Reply With Quote
Old 09-12-2010, 06:33 PM   #2
Rewards Points: 292
Is this your product? http://www.dap.com/docs/tech/00077312b.pdf
Maybe the bleach solution? Note where it says "Some cleaning products may affect the performance of this product." Also "Surface must be clean, dry and free of all old caulk, dirt, dust and grease. Rubbing alcohol is recommended for removing soap film and soil."
That should not be happening with this product.
Jim F is offline   Reply With Quote
Old 09-12-2010, 07:58 PM   #3
Yes, that's it. I read a few places that you should use a bleach/water mix to clean up after removing the caulk if there's mildew underneath, so that's what I did. Could that be the problem?
Old 09-13-2010, 11:14 AM   #4
Household Handyman
Rewards Points: 1,408
There was an excellent article posted here by a member that was several pages long in regards to caulking and/or re-caulking. One of the most important items he stressed was in preparations for caulking. Maybe do a "caulk" search or I may find it and post the link. David
Old 09-13-2010, 12:29 PM   #5
Thurman, is this the one you meant?
http://www.diychatroom.com/f2/recaul...r-frame-15069/
Looks good. I'm surprised I didn't find it the first time, but on the other hand, searching for "caulk" brings back several hundred results, so maybe it isn't so surprising.
I tried DAP's "Ask an Expert" e-mail, and they wrote back saying that the old caulk was probably silicon, and that's why the new stuff won't cure. They recommended using silicon to fix the problem because the old silicon will never really go away, although that's somewhat contradicted by the instructions in the link I posted above.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Best caulk for metal windows and brick walls Ginette General DIY Discussions 5 09-08-2010 05:29 PM
Best Bathroom Caulk for 2010? SimpleJack Plumbing 9 04-01-2010 04:12 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 07:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 05:30 PM
