Caulk - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 12:09 PM   #1
Rewards Points: 77
Caulk
I have some nails on apron flashing that need a little caulk, my question is what is the difference between exterior window caulk and roof caulk other than the color?
It seems both are used for similar applications, but am curious as to the specific properties of each.
troyce1 is offline   Reply With Quote
Old 01-07-2009, 01:24 AM   #2
Lightbulb
The roof caulk could have more uv resistance to it.
brakeless1 is offline   Reply With Quote
Old 01-07-2009, 06:33 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Roof caulks can often be urethane based to be compatible with roofing products. Window caulks are often silicone or latex based. If you are caulking to glass, wood or metal, use silicone or latex. If you are caulking to anything that contains any oil bases like asphalt, or to masonry use urethane.
Old 01-07-2009, 07:28 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
and always remember the good caulks are usually the expensive ones
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 04:08 PM   #5
Advice worth 2 cents!
Rewards Points: 150
With all due respect, that is NOT a good reply. Glues and adhesives must always be properly chosen by their chemical composition to achieve good results for each application. Price has nothing to do with the equation.
Maintenance6 has the right idea..
-pete
---pete
HandyPete is offline   Reply With Quote
caulk failed boston_michael Kitchen & Bath Remodeling 5 11-21-2008 05:30 AM
caulk question scatterbrain General DIY Discussions 5 10-04-2008 06:57 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 07:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 05:30 PM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 08:45 PM
