Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-26-2012, 07:04 PM   #1
Cart for Portable Generator
I have a portable generator that weighs about 200 lbs with gas and needs to be moved to my meter, when needed, which is about 100 ft. from the garage/house. It's very difficult, especially if muddy or if there is snow outside (it's also downhill, so bringing it back is especially difficult). Can anyone recommend a reasonably priced heavy duty cart? I've looked at some online, but many of them seem to have wheel bearing problems. Thanks.
Dave_T is offline   Reply With Quote
Old 01-27-2012, 06:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Most generators have wheel kits available for 'em,....
Or,...
Get a Big Extension cord, 'n leave the generator at the garage, 'n just haul out the Ex-cord...
Old 01-27-2012, 07:54 AM   #3
Why do you need to haul the thing out to your meter? Sounds like you're using some sort of illegal way to power your house during an outage.
md2lgyk is online now   Reply With Quote
Old 01-27-2012, 08:39 AM   #4
MarginallyQualified
how about leaving it out by the meter?
make a little shed or just use a tarp...
and don't forget to use the rest of the gear
TarheelTerp is online now   Reply With Quote
Old 01-27-2012, 08:46 AM   #5
biggles's Avatar
build a shed with an emergency flood light that comes on mounted right over the generator and bring the house into it.forget this dragging and hooking routine.you lose power walk out into the shed...transfer the house and start the generator and watch your neighbors get real friendly for some reason... check mine out in a detatched garage with the generator run up into the house panel Running Generator Inside Garage or Basement
Generator & Interlock Kit – Float the Neutral? Arnold Ziffel Electrical 12 01-13-2013 06:28 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
