Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-24-2011, 12:25 PM   #1
carport column replacement
how to replace a rotten carport column
hometime is offline   Reply With Quote
Old 01-24-2011, 12:37 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Relieve the Load on it, remove it, replace it, lower the load back down onto it....
Porch column base rotted RickO General Discussion 17 10-25-2011 09:43 PM
Tranferring load to basement beam and lally column cooperwd Building & Construction 3 08-17-2009 11:14 AM
Converting carport into a room troybliss Remodeling 8 08-14-2009 11:43 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 10:18 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
