Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-02-2012, 05:39 PM   #1
allphaser's Avatar
Carpet odor removal baking soda
After my carpet was cleaned a foul Odor appeared. I PULLED UP THE CARPET and applied Natures Miracle Advanced Formula spray. after 6 hours when dried I lightly vacuumed. i then applied Arm&Hamer Pure Baking Soda to the padding and carpet . Two four pound boxes!, My question is would it be ok to leave some of the baking soda under the carpet ? (hardwood floors with vented crawl space on dirt if that helps? I vacuumed as good as I could before placing the carpet back then vaccumed a second and third..
Thank you happy holidays!!
allphaser is offline   Reply With Quote
Old 12-03-2012, 06:51 PM   #2
well, if you vacuumed, it mostly shoyuld be sucked up, right? Then theres no problem. Otherwise, excess baking soda sitting on wood is not good. it IS a salt. Salt on wood can danage it over time. yes, baking soda is a salt......
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Pulled up carpet seam in doorway, now there is a gap... how to fix? thisisjason Flooring 3 11-19-2012 03:29 PM
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 06:54 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
