Caring For A CRAWL SPACE - General DIY Discussions - DIY Chatroom Home Improvement Forum
Poll: How to care for a crawl space
Poll Options
Old 07-16-2007, 06:54 AM   #1
caring for a CRAWL SPACE
I have a home in Maine with a crawl space.
should i put in windows that open, and any ideas what to put on the
dirt so the weeds dont grow??
bobbyfrommaine is offline   Reply With Quote
Old 07-16-2007, 11:47 AM   #2
(the original)
Rewards Points: 756
Default gives some good ventilation info. You didn't say what kind of foundation you have, chainwall, poured concrete, pier and beam? As far as ground cover, a lot of people use 6mil poly but a cross laminated vapor barrier is better, though quite a bit more expensive (and worth it, in my mind). Overlap the barrier and seal it with vinyl tape. 3m makes several for the purpose, I've used the 6mil gray. If you have a walled foundation, run the barrier about 6" up the sides and seal with adhesive.
ratherbefishin' is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Crawl Space under house bobbyfrommaine Building & Construction 1 07-10-2007 08:56 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 08:26 PM
Crawl Space needs "re-insulating" bigNY Building & Construction 1 10-12-2006 01:55 PM
