Carbide Tipped Hole Saw - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 11:04 AM   #1
Smile
carbide tipped hole saw
Hi,
Does any one know where I can get a good carbide tipped hole saw?
I'm fed up of mine breaking or just losing it's sharpness.
bobbybobster is offline   Reply With Quote
Old 03-02-2012, 11:40 AM   #2
Rewards Points: 13,968
I broke down and bought this set.
It cuts way faster then an hole saw I've ever used before.
http://www.cpomilwaukee.com/milwauke...ukee-hole-saws
Old 03-02-2012, 09:12 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,244
some big box stores will hve them, however your better off going to a tool dealer that caters to contractors in your region.. if that wont work try online
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
user1007 (03-03-2012)
Old 03-02-2012, 09:19 PM   #4
MarginallyQualified
Rewards Points: 2,464
I hate buying kits...
I'll assume that the mandrel portion is the same as other hole saws...
and I have a preference for Lenox.
Buy what you *need* when you need it.
Old 03-02-2012, 09:38 PM   #5
while yes, those do really chew though some wood, they are also quite a bit rougher than many other hole saws, i wouldn't really want to use it for any finish work.
sevenlol is offline   Reply With Quote
Old 03-03-2012, 05:21 AM   #6
Too Short? Cut it Again!
Might be overkill but if you are shopping for carbide you might as well at least price diamond. And before they all disappear, support your local sharperner for saw blades and drill bits. I rotated mine through on a regular basis, got chimp change pricing, had new bit and blades trued for free so they spun without wobble, and get free pick of the bits and blades people never came back to claim. I have great wood blades as a result.
I tend to dislike kits of any kind also. Buy the hole saw you need and not the six that come in a kit you will never use. And skip the switchable shank things. Pay the piper. Buy the nicely tooled hole saw as a unit, at a real tool store.
Should be asked? What your you putting holes in, what size, and really how often? Why are you dulling hole saws, unless they are cheap, at such a rapid pace?
Old 03-03-2012, 12:13 PM   #7
i forgot to mention,, that the need for carbide is solely based on the material you are drilling through.. im a carpenter by trade and just use regular hole saws, most often bosch or milwaukee. all i need hole saws for is for locksets in doors, pipes in the back of cabinets im installing or for electrical boxes coming through siding..
my electrician uses dimaond hole saws for cutting holes in plaster walls when he has to fish wires in older homes.. he claims he can easily drill 3-400 holes on one saw before its dead... compare that to a regular saw and your looking at maybe 25 holes
Old 03-03-2012, 05:10 PM   #8
Diamond is nice and usually the supporting structure fails before time before the cutting edge ever will.
We both agree. What are you cutting holes in, how often, and why are you dulling your cutting tools so fast. I have a hole saw, shared shank thing my grandfather gave me. I think parts of it have been used a couple times. I never even think to reach for the clunky thing.
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 05:55 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
