Capping My Chimney - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 07:55 AM   #1
Rewards Points: 150
Capping my chimney
Good morning,
I have recently updated/graded my furnace at home. I used to have an oil based furnace, but have recently upgraded for an electric unit. That being said, there is no need for an exhaust, and therefore my chimney isnt really needed anymore. The installer did "cap" the basement chimney hole (where the exhaust pipes used to connect to the chimney), but he didnt cap the chimney on the roof.
Im wondering what is the best way to cap the chimney on the roof. I managed to get a piece of aluminum, in which I could make a cap out of, or use a little "chimney hat" that my friendly neighbor gave me (he soo nice!!).
Here are a few pics to help illustrate what Im up against.
Here's my chimney, mine is the one on the left. Ideally, Id cap that little square part that's sticking out..
Here's the chimney hat my neighbor gave me...the legs are adjustable so it should fit no problem....
and here's a mock that I made out of paper, of what my aluminum cap would look like...
Installing the hat would be easier, but I want to avoid water issues. Im worried that drifitng snow/rain/ice or whatever could make its way into the chimney....
What would you suggest? Anyone done this before?
Thanks guys!!!
James
sbmfj is offline   Reply With Quote
Old 10-27-2011, 10:27 AM   #2
Rewards Points: 526
I personally would buy a lower profile rain cap. It will attach more securely, do a better job of keeping out rain and snow, and still provide air circulation.
Windows is offline   Reply With Quote
Old 10-27-2011, 09:31 PM   #3
cocobolo's Avatar
Rewards Points: 5,784
James, it sounds as though you really don't need a chimney any more if you won't be having any exhaust to get rid of.
I'm not going to suggest that you get rid of the whole thing, just in case you decide at some time in the future that you might like a wood stove.
Blowing snow is pretty clever stuff...it has a way of getting in places you wouldn't think possible.
I think I might cut some tight fitting foam board, maybe 2 or 3 inches thick, and fit that in the top of the chimney.
Then make up your metal cap, either aluminum or galvanized metal with the sides as long as possible and very snug fitting. Push it in place and caulk the bottom of it so nothing can get in or out.
That should do it.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following User Says Thank You to cocobolo For This Useful Post:
sbmfj (10-29-2011)
Old 10-28-2011, 06:52 AM   #4
Rewards Points: 150
Should I be worried about the chimney not having any more air circulation? Some people say I should, others say I shouldnt. Thanks!
Foam in the square hole, is that what you mean?
Old 10-28-2011, 10:03 AM   #5
cocobolo's Avatar
Yes.
And maybe you could block off the bottom of the chimney as well.
I don't know why you would need air circulation there, perhaps contact your local building inspector to ask why that might be.
And if the chimney is dirty, have it cleaned...this you can do yourself. The cleaning kits are fairly inexpensive.
sbmfj (10-29-2011)
Old 10-28-2011, 07:19 PM   #6
Rewards Points: 252
Do you also have an electric water heater?
Marty1Mc is offline   Reply With Quote
Old 10-29-2011, 08:41 AM   #7
Rewards Points: 150
yep! Why?
Old 10-29-2011, 09:55 AM   #8
Rewards Points: 252
If it were gas, it would need a vent, maybe that vent.
Old 10-29-2011, 10:30 AM   #9
cocobolo's Avatar
That's right Marty, it's usually a B vent for gas.
Old 10-29-2011, 10:45 AM   #10
biggles's Avatar
like suggested a thick piece of styrafoam board and shape it like a cork for a wine bottle but square so you can tap it down into the opening.take that sheet metal top on that other thing and cut and shape it so it fits like a hat over that opening.....predrill a small hole on each side to take a screw to hold it for future use....i would ace the chicken wire blowing snow and rain are going to work on that chimmney
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 06:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 07:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
