Can't Find Studs Behind Knotty Pine Paneling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-07-2006, 11:49 AM   #1
Can't find studs behind knotty pine paneling
Hi,
Total neophyte here. I'm trying to find the studs behind 60 year old tongue and groove knotty pine. Don't know how thick it is. I've tried 2 different electronic stud sensors and get seemingly random beeps and flashing LEDs. Tried both regular and deep scan settings. Is it hard for stud finders to peer through knotty pine? Will a fancy, expensive finder do a better job? Currently using $20 models. Tapping and listening yields nothing, as does my old magnetic sensor.
My wife is beginning to question my value around the house (maybe that's a good thing - keep her expectations low).
Any ideas?
David S is offline
Old 12-07-2006, 01:09 PM   #2
may be the problem is the surface is pine which is also wood... try to test your stud finder on regular drywall in one of your friend's house first see if it works... if it does... then it is the pine surface causing the stud finder unable to function... if it doesn't, then you can go get a better stud finder, mine is standley which is quite good, it is more expensive, but I got it from Ebay(new) around the same price as yours after shipping added, you will be surprise to get good deal from Ebay for things like that... such as $4.99 for a new Standley stud finder...etc. which is a small thing where not too many people chasing it...
KUIPORNG is offline
Old 12-07-2006, 01:44 PM   #3
747
registered
747's Avatar
Rewards Points: 534
Well it should be this simple. Buy a tape measure which is marked with studs. Start at a door way or where two walls meet and stretch the tape measure out you should be in the vicinity.
Ps. I think walls are built either 12 or 16 inches on center depending on what there carring. If i'm wrong one of the carpenters will correct me.
747 is offline
Old 12-07-2006, 01:52 PM   #4
don't trust the 12 or 16 inches... I did my basement... I didn't follow 16 inches on all studs although many does... it changes on circumstances...
KUIPORNG is offline
Old 12-07-2006, 03:02 PM   #5
concretemasonry's Avatar
Rewards Points: 2,566
Could there be horizontal strapping with the vertical boards applied to it?
concretemasonry is offline
The Following User Says Thank You to concretemasonry For This Useful Post:
oh'mike (09-05-2010)
Old 12-07-2006, 03:29 PM   #6
Log-Style Home Contractor
North Country's Avatar
On a properly framed house, O.C stud spacing is pulled from one end of the house, walls/doors should not affect these. To find the studs on Horizontal T&G paneling see if you can see the nails or nail Gouge under/near the tongue, or if that fails then at the top of the wall, possibly under a trim strip. If you see any, then pull your 16" from there. On Vertical T&G there will be furring strips behind them, probably on 24" centers either from bottom or top plates. T&G is one of our specialties. Hope this helps
North Country is offline
Old 12-07-2006, 05:52 PM   #7
Reason to locate the studs?
Is this an interior wall or exterior wall?
redline is offline
Old 12-07-2006, 06:08 PM   #8
Thanks all for your responses so far.
My sensors do work properly in other rooms where there is drywall.
So, if I understand correctly, an electronic sensor won't work to find the studs behind the vertical knotty pine because there's an air gap corresponding to the thickness of the horizontal furring strips between the paneling and the stud, right?
So, is there a good method for finding the stud behind the knotty pine? I want to hang a 100 lb. television. The paneling seems very solid. I wonder if I should even think about just screwing into the pine paneling and hope it holds.
David S is offline
Old 12-07-2006, 06:11 PM   #9
Interior wall.
David S is offline
Old 12-07-2006, 06:19 PM   #10
Originally Posted by David S View Post
Interior wall.
If this is an interior wall then I would go to the other side of the wall in the room adjacent to it. Hopefully, the opposite side of the wall is drywall. Find the studs on this wall, measure where they are and then correspond the studs with the measurements in the room with the knotty pine.
Your sensor may not work on the knotty pine if it is detecting the nails that are used to attach the knotty pine to the walls.
redline is offline
Old 12-10-2006, 06:21 AM   #11
Rewards Points: 346
Try an old fashioned stud sensor, the kind with a magnet. If you locate the nails it is likely you will have found the studs. Once you find a nail check up and down to for other nails. When you find nails in a straight line you found the stud. If that doesn’t work and finding a stud is critical try removing the base board. Be sure to score the paint (or finish) with a sharp knife and very carefully pry it off with a putty knife and a small pry bar so you can replace the trim with minimum damage. To replace the trim pull the nails out from the back of the board and replace with new finishing nails.
RegeSullivan is offline
The Following User Says Thank You to RegeSullivan For This Useful Post:
Willie T (09-05-2010)
Old 12-10-2006, 11:15 AM   #12
joed's Avatar
Rewards Points: 11,556
Find a receptacle. It will be nailed to one side of the stud. Then measure from there.
joed is online now
The Following User Says Thank You to joed For This Useful Post:
Old 09-04-2010, 12:44 AM   #13
This is the best suggestion I found. It worked great for me. Even though this is not my original post. It answered my question. Thank you.
cece is offline
Old 09-05-2010, 05:03 PM   #14
Tizzer's Avatar
Rewards Points: 452
I'd do as N.Country mentioned and/or the receptacle idea. Look down at the baseboard to determine which side of the stud the rec. is nailed to.
Usually, baseboard is nailed to a stud but in your instance, they could've just nailed it to the panel board.
You can use a prybar and gently pull away some of the baseboard to see if you can spot where the T&G was face nailed.
Tizzer is offline
Old 09-05-2010, 05:33 PM   #15
Original post is almost 4 years old
Scuba_Dave is offline
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Tizzer (09-05-2010)
Closed Thread
knotty pine paneling Unregistered Remodeling 2 03-22-2010 12:41 PM
knotty pine paneling harleyd1369 Carpentry 3 11-19-2006 12:01 PM
How to find studs behind stucco Newbie1 Building & Construction 2 12-29-2005 10:22 PM
Cleaning knotty pine t/g boards barks Painting 3 03-22-2005 12:13 AM
Cleaning knotty pine boards barks Remodeling 4 03-17-2005 09:55 PM
