-   -   Can't figure out a smell in my room (http://www.diychatroom.com/f2/cant-figure-out-smell-my-room-158271/)
dariusld 09-28-2012 02:02 PM
I just purchased a house recently. My bedroom had a funny smell to it. I painted all the walls in the whole house. I replaced the carpet and padding in the room, thinking that might be it. The concrete floor under the carpet looked fine. The smell, I thought, was gone:no: It was just the new carpet smell masking it. The smell is worse when the room is all closed up and when I first enter the room. The smell seams to soak into everything in the room. I can smell it in my clothes. I went in the attic and cleared away the blown in insulation and looked at the drywall that appeared fine. The room has one wall on the outside, one against the garage, one on the hallway, and one against another room. I pulled the garage drywall down and the bedroom drywall looked fine on the bedroom side. I replaced the garage side drywall. Now the last wall that I think may be a problem is the one facing outside. I'm thinking there might have been a leak or is a leak.
I don't have a lot of experiences with smells, so I don't know what smells are what. I asked the fumigation guy if it smelt like something he was familiar with and he said moisture. I asked my mom and she said it doesn't smell like a mold or moisture issue to her, more like a chemical smell.
user1007 09-28-2012 03:17 PM
Without you posting some scratch and sniff it is going to be hard to help you I fear. If you have eliminated the possibility all walls but the remaining ceiling one I guess it is worth a peek in there. You might cut a small holes (taking care not to nick electrical and see if anything is obvious with a flashlight and dental type mirror before you rip the whole wall out. I would look around the window as that is the most likely place for a leak.
Any chance a small animal got in the wall?
You know, sometimes we have gotten so good at tightly sealing and wrapping homes they just need some fresh air. Do you have decent ventilation in that room?
BigJim 09-28-2012 03:18 PM
If you have gas heat and a gas water heater that would be the first thing I would check to be sure there are no dangerous fumes coming from there. Next I would check the drains in the house to be sure they are all working properly, not leaking and have water in the traps. I would check to see if the plumbing vents on the roof are open and working as they should.
If there is something that has soaked into the concrete you can get a product at Wal-Mart or most groceries called Odoban, it is cheap and it does work, it doesn't cover the smell it eliminates it.
DexterII 09-28-2012 03:35 PM
A dead mouse in the HVAC ducts?
dariusld 09-28-2012 04:28 PM
Forgot to mention that I checked the vent for that room all the way back to the main line. If it is a dead animal, I would think after 6 months of living here, the smell would be gone? Before I moved in the house was tented. I found two dead rats and a mouse, but they weren't above the room in question. When I checked the ceiling in the attic, I went through a lot of the blown in insulation and didn't find any dead critters. I don't know if it matters, but when I replaced the carpet I cleaned the floor with bleach. Venting the room helps a lot, but the smell comes right back when I close the window and door. The last wall I have to check has a window in it, so maybe it's mold from a leak. The roof has gutters and before I repaired them, the water really hit that side of the wall. I just hate to have to do all that work and not find anything:( And I'd hate to use the hole method and not be thorough and miss something.
You guys are really helpful, Thank You!
DangerMouse 09-28-2012 09:00 PM
If it's more like a "chemical" smell, I'd be looking towards the drywall. It may be that "Chinese drywall"....
DM
dariusld 09-28-2012 09:59 PM
DM
I Googled it and it made it sound like most of that went to Florida and that area. I'm in San Diego. And Home Depot and Lowes said they didn't get any.
user1007 09-28-2012 11:46 PM
Which minimum wage person at either assured you of this?:laughing:
