-   -   can you paint flat paint over semi gloss (http://www.diychatroom.com/f2/can-you-paint-flat-paint-over-semi-gloss-121418/)
Keg 10-26-2011 05:53 PM
Hello everyone I have a question. The original ceiling was flat and I put semi gloss now. like people said roller marks and imperfections appear. can i buy flat again and go over semi gloss or do i have to do something more like prime it.. thank you all
ddawg16 10-26-2011 08:13 PM
You can do what ever you want. Flat over Gloss....gloss over flat.
Have you considered putting a second coat on it first? I personally have not had a whole lot of luck getting by with just one coat of paint when I'm changing colors.
What kind of imperfections? In most cases that is caused by dirt, and not the paint it self. When in doubt, prime it....then paint it.
Keg 10-26-2011 08:53 PM
Hi dawg thanks I see the roller marks on the ceiling and the beams from the attic show more now then before.i guess because there is four windows all is seen on the ceiling. I did two coats. when it was a flat China white it was nice. used semi gloss over it and when you open curtains lighting shows everything. Should I buy a flat China white with primer. Some people posted sanding it down before going over. it seems allot for a bedroom ceiling. Or should I just buy flat china white.i appreciate all the help. Thanks
Ron6519 10-26-2011 09:16 PM
You might want to lightly sand the ceiling. The area needs a bit of tooth for the next coat to grab onto. You also want to mute some of the thicker rolling issues so they don't telegraph through the next coat.
Keg 10-26-2011 09:47 PM
So regardless it needs sanding? Or a paint with primer would make it work. or straight primer then flat.. thanks sorry just been frustrated with this project :(
ben's plumbing 10-26-2011 10:18 PM
not sure where you are from but sherwin williams pro mar 200 is some awesome paint ..primer and top coat.....was told anytime changing surface finish always prime.......
Keg 10-26-2011 11:13 PM
Awesome thank you all so much
user1007 10-27-2011 07:14 AM
Pro Mar is SW's contractor grade paint. Great paint. Used to use it all the time but it is not their top of the line. Still much better than any box store brand.
Remember that latex/acrylic semi-gloss paints take 30 days to cure. If you try to sand or scruff the surface before then you could have a mess on your hands and sheet upon sheet of gummed up sandpaper.
I would tend to go with the suggestion to stay with semi-gloss---especially if you after that sheen in the first place---and apply another coat with a thicker roller cover.
pshadwick 10-27-2011 09:04 AM
Another thing to keep in mind when using any kind of gloss on the ceiling is that the direction of rolling makes a difference.
You should always roll towards the windows, the roller marks are then much less noticable.
...Paul
Keg 10-27-2011 09:15 AM
Do you think if I change the nap to thicker would it help cover the roller streaks. I'm not applying pressure to the roll when applying. The guy told me to use a thinner nap. wondering if it would be better to go thick. Also been reading that primer would be fine then flat paint over. Would that stick ok? Or sanding is the only way? Thanks
Windows 10-27-2011 09:56 AM
Give it a light sanding - use a thicker napped roller, but spend the time back-rolling and really evening out the paint. Do two coats of flat. You are seeing roller marks not because it is semi-gloss, but because either you are having coverage issues (not enough paint on the ceiling) or you are not rolling it out properly, or both.
user1007 10-27-2011 10:41 AM
What nap cover are you using. I seldom used anything thinner than 3/8 and usually started with 1/2 for interior work and latex paints. Other painters disagree but I actually preferred 3/4 when applying semi-gloss---especially to walls and ceilings.
You could put a high bond primer on to be sure of adhesion if you want to shift to flat. Once it is cured, a light sanding will go really fast.
seamonster 10-27-2011 10:54 AM
I suggest priming over glossy walls for adhesion but if its a ceiling you really dont have to. I dont see why you'd want to sand at all. We use Benjamin moor and whenever there are roller marks, its just telling us we need another coat.
Keg 10-27-2011 11:07 AM
I know Behr has primer inside the paint. is that good enough to cover semi gloss?
Windows 10-27-2011 12:01 PM
Get a typical flat ceiling paint from an actual paint store and you are good to go. Paint and primer in one can is nothing more than a sales gimmick.
