Can Vibrations Cause A Leak - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-11-2009, 10:47 AM   #1
Unhappy
Can vibrations cause a leak
Was wondering if someone could help is it possible that heavy drilling could cause the main radiator bleeding valve to leak, the council will not accept liability for a leak i believe was down to the work they had carried out next to the valve
sweetashuny is offline   Reply With Quote
Old 04-11-2009, 02:15 PM   #2
Registered User
Rewards Points: 5,216
I would say, yes, but only if they are both on Planet Earth, and reasonably close. Post this in Plumbing forum. Be safe, GBAR
Old 04-11-2009, 03:40 PM   #3
so is that really a yes or are you taking the mickey out of my question ?
Old 04-11-2009, 03:51 PM   #4
Rewards Points: 5,336
Define, "heavy drilling". What were they drilling into?
The valve would not have been tightened properly for it to leak so easily, unless you're jack hammering concrete.
Ron
Old 04-11-2009, 07:56 PM   #5
thanks for the reply
they were using some kind of hand held jackhammer to demolish a bricked wall and concrete in the chimney breast wall. Do you think this could have caused the leak ?
Old 04-11-2009, 08:04 PM   #6
Registered User
Could you "feel the Earth move under your feet"? Then YES! Especially if the pipe coming in is on the same side as the work done.
Be safe, GBAR
Old 04-11-2009, 09:59 PM   #7
yes i felt the earth move
So is that a yes to the vibrations causing the valve to lossen and leak ?
Old 04-12-2009, 10:34 AM   #8
It's a possibility, but nothing posted here will convince , "the council" to take responsibility.
Go through your insurance company. Tell them the story. If they believe someone else caused the issue, they will persue it with their insurance company. But in the meantime you will be able to do repairs.
Ron
Old 04-12-2009, 11:47 AM   #9
Civil Engineer
Rewards Points: 4,568
This is a DIY forum, not a venue for uninformed legal judgements about liability, responsibility, or other legal ramifications. So if you post a legal question, you should expect to get uninformed answers, if you get any at all. If you are interested in how to fix the problem, or prevent it from recurring, that is a different matter, as many of the folks on this forum would be excellent resources for questions like how to replace a valve, or fix the valve etc. But free legal advice? I doubt it.
Old 04-12-2009, 12:15 PM   #10
Extensions
vibrations can cause more than leaks - but it won't be easy to prove that
regards
extensions is offline   Reply With Quote
Old 04-12-2009, 10:14 PM   #11
Rewards Points: 562
how do you know that a shirt sleeve didnt rub across it and open it a bit?? or is it harder than that to open?? Was it in a place that could have been 'bumped'?
4just1don is offline   Reply With Quote
Tags
damage , leaks , valve
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 09:46 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
