Can Someone Help With Backfill Advice. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-01-2009, 09:48 PM   #1
Can someone help with Backfill advice.
I had my home remodeled last summer, and had my fireplace chimney removed.
At finish grade level to the bottom of my foundation, the poured chimney footing remains. I started a project to knock this down with the sledge and clean this up a bit so I can get all of the poured chimney footings under ground so I can put my rock bed over and conceal it. Old reminients of the chimney were caved in and the debris filled the chimney (Dirt,Bricks, Concrete) .
I decided to go further and started to dig all of the debris out of the hole while I am at it though because after a heavy rain, I am getting some water in my basement through this area now. My whole home is poured walls except where the chimney is located is masonry block.
I am wondering when I get all of the brick and stone cleaned out of the old chimney what I should do to backfill it. I assume with all of that in there the water is getting down my foundation way to easily.
Once I get it all cleaned out, do I backfill it with sand? Any thing else I need to be doing to make this right? Any help you can provide will be greatly appreciated. Thanks!
Deuce73 is offline   Reply With Quote
Old 07-02-2009, 07:05 PM   #2
Registered User
Rewards Points: 526
I am not a mason. I would waterproof the exterior wall where chimney was, then fill the hole to just overflowing, apply a waterproof plastic over the hole, overlap the chimney foundation sides, and up the wall a little. Apply a waterproof exterior foundation board over the blocks above grade. With it overlapping the plastic at bottom and z- flashing on top. Water should shed to past the chimney foundation where it never leaked before. The weak point being the plastic--- any thoughts, any one?
Be safe, G
Old 07-03-2009, 07:54 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,...
I'd quit digging,+ cap it below grade with Concrete, sloped away from the house...
Old 07-03-2009, 08:01 AM   #4
Originally Posted by Bondo View Post
Ayuh,...
What he said!
Shamus
Shamus is offline   Reply With Quote
Old 07-04-2009, 05:38 AM   #5
Thanks Guys. Love you idea Bondo. I had just spoke to my Dad the day before your post and he suggested exactly the same. Much Easier and a better solution to my idea.
Thanks for everyones advice.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Backfill for garage sadkins Building & Construction 5 10-03-2008 04:22 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
