Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-14-2006, 04:03 AM   #1
Can a manual tile cutter cut granite, marble, etc?
Or do I need a wet saw? tia
Krichton is offline   Reply With Quote
Old 08-14-2006, 03:33 PM   #2
How thick is the material?
redline is offline   Reply With Quote
Old 08-14-2006, 09:11 PM   #3
You need a wet saw or angle grinder with a diamond blade, manual cutters don't cut stone, just glazed ceramic.
R&D Tile is offline   Reply With Quote
Old 08-18-2006, 12:16 AM   #4
Floorwizard's Avatar
Absolutely your right.
Floorwizard is offline   Reply With Quote
Old 09-04-2006, 02:21 PM   #5
Home Improvement Guy
ron schenker's Avatar
I agree, just finished a granite floor job and used both. The angle grinder worked perfectly for round toilet flang hole and heat register cutouts.
One word of advice...don't use cheap blades, buy the best you can afford!
ron schenker is offline   Reply With Quote
Marble Tile Countertop? Sportbilly Remodeling 16 12-09-2012 04:29 PM
Help on materials needed for granite tile c4m4r0 Flooring 4 06-02-2007 03:05 PM
what do you think about those cordless tile cutter KUIPORNG Flooring 1 08-21-2006 11:15 AM
Granite Tile ....on wall ? mahjohn Building & Construction 7 03-01-2006 08:55 PM
