Can I Remove Dividing Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2008, 12:24 PM   #1
Can I remove dividing wall
I have a 1950's home. They added an extension at one point, but in the basement they left the concrete dividing wall in place so you can't actually get to the other side of the basement(below the new addition) unless you crawl through a large window that must have been the outside window of the original home. Is it safe to me to remove enough blocks(2 or 3 per level) so that a person can at least walk from one side to the next? I don't see how the concrete blocks under the window openeing actually support anything, so I was hopeing to remove some. Any thoughts? Or who can I call about such things? I've attached a couple images.
Can I remove dividing wall-insidetoout.jpg   Can I remove dividing wall-outsidetoin.jpg
QuestionGuy is offline   Reply With Quote
Old 03-30-2008, 03:32 PM   #2
Rewards Points: 6,652
You should be able to. Just do not remove any more then you have to, to make the opening down to the Slab.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Can I remove a wall? timber General DIY Discussions 13 12-07-2007 10:24 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Want to remove wall found heating/ducts wondrgirl HVAC 2 06-04-2005 10:54 AM
