Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-24-2009, 08:56 PM   #1
Can I pull a blanket type siding permit?
I have plywood siding t111 and my location requires a permit. The problem is i don't know exactly which pieces I'm going to replace. I won't know until I start prepping the surface for painting. How does the permit process normally work for just siding? Do I have to state in a diagram which side of the house I will be doing the work on or can I just pull a permit that states siding? I will then show the inspector which pieces I replaced. I'm not sure either if they need to inspect the framing prior to putting on the siding to see that it is in good condition.
pomelo is offline   Reply With Quote
Old 01-24-2009, 10:48 PM   #2
Tom Struble's Avatar
here where i live you can replace/repair a certain percentage with out a permit.Ask your building dept
Tom Struble is offline   Reply With Quote
Old 01-24-2009, 11:12 PM   #3
Moderator
Termite's Avatar
Each city will be different. Some don't require a permit at all, some do. You need to call them and ask.
Old 01-27-2009, 02:52 PM   #4
Jer
In my area you would not need a permit but in areas near me there are areas considered "historic" which are tightly regulated as far as matching original siding materials.
Jer is offline   Reply With Quote
New siding, paint exsisting siding, or powerwash?? fixiechick General Discussion 5 01-23-2009 12:50 AM
Pressure washing painted houses nightman General Discussion 6 02-05-2008 09:23 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
