Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-20-2005, 11:32 PM   #1
can I move W/dryer from kitchen to garage?
I am moving my washer and dryer to the garage which is right behind my kitchen. By opening the white box in the laundry closet in the kitchen (hot & cold pipe+ drain hole) I see a wood plate after the insulation. I was hoping to see the drywall. Wondering if I can cut thorough it or not to open a hole for access to the pipes from garage? I also need to do the same for the elect. Outlet. I am concerned about the codes and regulations.
amsmk is offline   Reply With Quote
Old 09-21-2005, 01:04 AM   #2
Contractor
First you need to check your local codes. Here, it wouldn't be a problem, most mid-range homes are putting them there.
Teetorbilt is offline   Reply With Quote
Old 09-21-2005, 07:27 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Ditto
It's a local thing
slickshift is offline   Reply With Quote
Old 09-21-2005, 10:43 AM   #4
I'll do that.
Old 09-22-2005, 01:07 AM   #5
Originally Posted by amsmk
I'll do that.
Will your garage ever go below 32 degrees F.
K2eoj is offline   Reply With Quote
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
