-   General Discussion (http://www.diychatroom.com/f2/)
-   -   can I move W/dryer from kitchen to garage? (http://www.diychatroom.com/f2/can-i-move-w-dryer-kitchen-garage-1050/)
amsmk 09-20-2005 11:32 PM
I am moving my washer and dryer to the garage which is right behind my kitchen. By opening the white box in the laundry closet in the kitchen (hot & cold pipe+ drain hole) I see a wood plate after the insulation. I was hoping to see the drywall. Wondering if I can cut thorough it or not to open a hole for access to the pipes from garage? I also need to do the same for the elect. Outlet. I am concerned about the codes and regulations.
Teetorbilt 09-21-2005 01:04 AM
First you need to check your local codes. Here, it wouldn't be a problem, most mid-range homes are putting them there.
slickshift 09-21-2005 07:27 AM
Ditto
It's a local thing
amsmk 09-21-2005 10:43 AM
Thanks Guys
I'll do that.
K2eoj 09-22-2005 01:07 AM
Originally Posted by amsmk
I'll do that.
Will your garage ever go below 32 degrees F.
