Can I Install Ceramic Tile Onto An Uneven And Un-level Concrete Floor? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 09:35 AM   #16
yummy mummy's Avatar
Rewards Points: 1,016
Originally Posted by Bud Cline View Post
OK then Go ahead!
You are still so funny,.....
yummy mummy is offline   Reply With Quote
Old 02-03-2011, 10:17 AM   #17
DIY staff
Rewards Points: 7,174
Use ceramic on top you will be fine---Look at Jiffset and Linewebers latex--read the directions---
add sand to the deep parts--makes it stronger and cheaper---mix it thin --work fast--
I've been using that brand for 18 years without an issue---Mike---
Old 02-03-2011, 08:43 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Mapei International is one company that makes and sells Self Levelling Compound that is intended to be a wear-surface and is intended for use when acid-etch staining. Take alook at their website. You'll have to sift through their SLC products but it's there.
Ardex is another.
XXX
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 10:09 AM
Base cabinet install on uneven floor no1hustler General DIY Discussions 4 10-13-2010 02:52 PM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 06:49 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 10:01 PM
