Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-05-2009, 01:54 PM   #1
Question
Can I give 12V DC to power inverter through PC Power supply?
I'm having a question whether i can give power to inverter using a PC power supply?
The Specification for the one i'm gonna use is provided below.
please advise me in this regard.
Specification:
1200 Watt Continuous
2400 Watt Peak Surge
Model No.
PI-1200W-12V Continuous Output Power
1200W Max Output Power
2400W DC Input Voltage
DC 12V AC Output Voltage
230VAC/240VAC Regulation ±5% Frequency
50Hz±3% Efficiency
87% No Load current Draw
0.7A Output Wave Form
Modified Sine Wave Distortion
2% Temperature Protection
(55±5) Input Low Voltage Protection
YES Input Reverse Polarity
YES circuit protection
YES Output Short Circuit Protection
YES Overload Protection
YES
inverter is offline   Reply With Quote
Old 07-05-2009, 02:31 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Assuming you have a good reason for doing this, I'd check that the DC voltage input to the inverter from the PC supply doesn't exceed inverter input limits, within the range of the loads you are putting on the inverter output.
PC switching supplies may be persnickety about what load they are seeing.
Old 07-06-2009, 06:51 AM   #3
Specification:
Model No.
50Hz±3% Efficiency
YES
Expect the total power available from a modern pc psu's 12volt rail to be about 200watts. If you use that to power an inverter expect ~150-175 watts available at the output of the inverter. If your load exceeds 200watts the pc psu will probably shut down.
A 500w pc psu I randomly selected at newegg provides 12V@16A.
That is 192 watts.
Another option for a large inverter like this is a car battery or deep cycle battery.
billmee is offline   Reply With Quote
Old 07-06-2009, 10:38 AM   #4
joed's Avatar
1200 watts @12 volts is 100 amps. Do you have a PC power supply capable of 100 amps or 200 amp peak?
Do not PM with questions that can be asked in a forum. I will not respond.
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Power inverter AndrewL Electrical 6 03-02-2008 02:43 PM
wiring up two lights to one power supply divy Electrical 6 02-11-2008 06:49 AM
Need a new power supply Alan PC Repairs & Upgrades 18 06-15-2007 01:57 AM
