Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-28-2008, 09:22 PM   #1
Can I dye existing brick mortar?
We just bought a new house which we absolutely love, but the mortar is the same color as the brick, and I'd like to bring out the mortar lines with a lighter color. Is there any way to dye or paint mortar without screwing it up or do I have to live with it the way it is? I don't want the bricks to be affected, just the mortar.
Thanks in advance for any help you can give.
Kevin
Foo by Tore is offline   Reply With Quote
Old 05-26-2008, 09:37 AM   #2
concretemasonry's Avatar
Keep in mind - If you "dye" or "stain", you are changing the color or hue, but cannot make anything lighter. To get lighter, you have to coat, which gives you a surface with increased maintenance. Mortar, and especially brick, are hard to lighten since most bleaching materials will damage/destroy the mortar.
Products with a clear vehicle carrying a gooing staining pigment (like a iron oxide) will only make thing redder, browner, or blacker, but not lighter.
Dick
concretemasonry is online now   Reply With Quote
Old 10-30-2008, 08:03 PM   #3
Hope this is not too late.
Recently a "mason" repointed old stone work on my house using tinted mortar that was too dark. I was able to lighten it with a paste of oxalic acid.
Oxalic acid is available in powder form from many hardware stores. It is a mild acid and is actually found in some vegetables. Although the maker doesn't recommend getting it on the skin, it has never bothered me when I use my fingers to get it where needed. One of the uses listed on the box is to remove rust stains from cotton fabric. I've used in the past to remove rust stains from the tub, shower, toilet and concrete on the porch.
To bleach the mortar, I added enough water to the powder to make a paste that I applied to the joint. After it dried, I hosed it off. The maker recommends neutralizing it with borax, but I just hose it off with plenty of water.
Hope this helps
mostlydim is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Dryvit or Stucco over Existing Painted Brick andrew2008 Building & Construction 4 03-22-2011 07:58 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
Brick steps failing sk8z Building & Construction 10 03-28-2009 04:16 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
