Can I Continue To Use Garage Door Without Torsion Spring? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 10:27 PM   #1
Rewards Points: 588
Can I continue to use garage door without torsion spring?
Just bought a house and it looks like the torsion spring is broken on one of the garage doors. The garage door opener, a Chamberlain LiftMaster 3280, appears to open and close it without issue. I don't know how long it has been this way.
Can I continue to use it this way or do I need to replace the torsion spring?
noone is offline   Reply With Quote
Old 05-08-2011, 10:38 PM   #2
BIGRED
Rewards Points: 252
Replace the spring. If the opener fails the door could come down hard on you or someone else without warning.
Grampa Bud is offline   Reply With Quote
Old 05-08-2011, 10:40 PM   #3
Rewards Points: 588
Is this a DIY job or not recommended?
The Following User Says Thank You to noone For This Useful Post:
jbfan (05-09-2011)
Old 05-08-2011, 10:50 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Not DIY recommended.
jbfan is online now   Reply With Quote
Old 05-08-2011, 10:51 PM   #5
Rewards Points: 558
If you have any doubts about your abilities to do risky physical work on your own, hire the job out like everyone else.
epson is offline   Reply With Quote
Old 05-08-2011, 11:19 PM   #6
Rewards Points: 588
I have under my belt: laid tile, wood, drywall work, studding work, indoor plumbing, trim carpentry, cleaned blower wheels and evaporator coils on air handlers and cleaned the outside condensors.
Am I qualified to do this on my own? Or is it just not worth the hassle?
Old 05-08-2011, 11:21 PM   #7
BIGRED
Rewards Points: 252
If you are very mechanically inclined you might be able to do it safely with the correct tools for your particular drums. I have replaced Torsion springs on three different doors over the years, myself, but I don't have the upper body strength anymore to do it safely. Also if one spring breaks or lets go you should replace both of them because the unbroken one has taken on severe stress at the time of the other break and most likely will not wind/unwind smoothly or correctly when the new one is put in on the other side. Be safe, listen to these other guys and just call a garage door company. An opener is one thing, but getting hurt with those springs is quite another.
The Following User Says Thank You to Grampa Bud For This Useful Post:
nap (05-09-2011)
Old 05-08-2011, 11:26 PM   #8
Rewards Points: 588
This door has only one spring.
I'll call a Garage Door company.
Thanks for the comments.
Old 05-09-2011, 07:03 AM   #9
DIY staff
Rewards Points: 7,174
Good ,safe move----Tightening a garage door spring is a dangerous and even deadly job.
---Mike-----
Old 05-09-2011, 09:14 AM   #10
Chicago, IL
Michael Thomas's Avatar
I definitely do NOT recommend maintenance or removal of torsion-type garage door springs as a DIY project, but if you want some idea of what can be involved, take a look here:
How I Replaced Deadly Garage Door Torsion Springs ... (and lived to tell the tale)
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 05-09-2011, 09:27 AM   #11
A Little Of Everything
Rewards Points: 1,364
Good move!
I'm a relentless DIYer, but I wouldn't touch a torsion spring on a garage door. A good buddy of mine - retired from an overhead garage door company - says that unless you have the right tools and the right knowhow, those things can kill you. Literally.
DrHicks is offline   Reply With Quote
Old 05-09-2011, 06:57 PM   #12
Rewards Points: 2,634
Besides the risk that Bud mentioned, you will detroy the plastic gears in the opener if you run it without having the door properly counterbalanced.
SPS-1 is offline   Reply With Quote
Old 05-09-2011, 08:56 PM   #13
Rewards Points: 282
last time i replaced my springs it was 150 bucks for 2 springs and the labor. you cant beat that.
jcrack_corn is offline   Reply With Quote
Old 05-09-2011, 09:00 PM   #14
Rewards Points: 588
I have a recommended garage door repairman coming tomorrow to replace the single spring on the one car door for $125. He is also going to replace the belts on 2 Liftmaster 1280R units for $30 each including parts.
I'm satisfied.
Thanks for all the comments.
Old 05-09-2011, 11:37 PM   #15
Rewards Points: 212
Not true. It takes a certain number of turns of the shaft for a door to go up or down. That number is determined by the size of the door and the diameter of the pulleys. Lets say that number is 6. (actual number doesn't matter) If both springs are there, lowering the door winds each spring 6 turns If one spring is broken, lowering the door winds the other spring 6 turns. The tension on that spring is exactly the same.
A Squared is offline   Reply With Quote
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 10:03 PM
Can garage door opener circuit continue to do other things? DIYGST Electrical 7 04-14-2010 08:24 PM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 10:24 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
