Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-28-2006, 11:16 PM   #1
Exclamation
Can Durock Build an entire house?
Is this possible? I was told so but can't fully see it.
chatman is offline   Reply With Quote
Old 12-29-2006, 02:17 PM   #2
renovations
No, but builders can.
If you mean, could you use durock in place of drywall throughout a house, I'm sure you could, but why would you want to?
Bonus is offline   Reply With Quote
Old 12-29-2006, 03:53 PM   #3
very tight budget. That's why.
Old 12-30-2006, 02:21 PM   #4
renovations
Durock is harder to cut, install and finish than drywall, or everyone would use it. Still not sure I'm understanding the ?
Old 12-30-2006, 04:08 PM   #5
Ok it's like this. We wanna build wall house here in Barbados but the total came to $230.000. Way too much for us. So we heard of Durock. And many high class people use Durock to build their houses. The foundation was mainly blocks, cement etc, while the walls was made of Durock . And now today I found out that it was something called Cement Board that was used. You know anything aout this Cement board?
Old 12-30-2006, 05:27 PM   #6
Is this for interior wall surfaces or exterior wall surfaces?
redline is offline   Reply With Quote
Old 12-30-2006, 06:39 PM   #7
concretemasonry's Avatar
Much of the area uses concrete block for the home itself because of wind and hurricanes. Are you covering the block walls?
concretemasonry is online now   Reply With Quote
Old 12-31-2006, 10:02 AM   #8
I'm not into construction. We are looking for a very cheap way to build wall house without using blocks for walls period. I was told that Cement board can be used as walls. Foundation will be blocks.
Old 12-31-2006, 12:25 PM   #9
joed's Avatar
Cement board, durarock, wonder board, what ever you want to call it is screwed to studs. If that is a permissible building method in Barbados and is cheaper than block wall is, I suppose you could build with it. It would have a lot joints that would need to be filled. A coat of stucco or something would be required.
Old 12-31-2006, 12:31 PM   #10
Instead of looking for a "cheap" way to build a house, why not build smaller with quality and add on in the future when you can afford it? I'd always side with quality!
Not Sure is offline   Reply With Quote
Old 12-31-2006, 01:35 PM   #11
Just remember the three litle pigs. The block should not be too much $$ when you consider the end result.
They do make cement walls but it's not durarock. That is for backing tile in a bath or other wet area. The cement walls are more like a prefab stand up wall made from concrete. Good luck
halleloucu is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
Will my house make my kids sick??? jokrupinski General Discussion 18 09-29-2006 05:05 AM
