Can A Birch Wood Table Be Used Outside On Deck If Treated Or Sealed? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 09:18 AM   #1
Can a Birch wood table be used outside on deck if treated or sealed?
I have a kitchen table in my home that i was going to get rid of because it is a little large for my kitchen. Then i thought about it as i was also looking for a new table for my deck, That my kitchen table would fit and work perfectly on my deck outside.
Its VERY strong and solid. I did not pay much for it, So i am not to concerned if the weather does a little damage to it.
Its made of all birch wood and i was wondering, If i were to buy some type of water sealer or wood sealer or anything and covered the table from top to bottom with it, Would it last outdoors thru the weather and rain? or not?
I know i can simply buy a outdoor table but i would really love this table outside, Thats if i can some how seal and protect it from the weather.
mafmmx is offline   Reply With Quote
Old 04-08-2012, 11:32 AM   #2
I see nobody has answered your post. I will give it a shot. Birch is not a durable exterior wood so don't expect much. Putting a marine spar varnish on it is better than most other store shelf finishes. Spar varnish has to be re-applied after a few years, though, because it breaks down from UV rays. I am in the process now of working with a kitchen customer on refinishing her countertop with a sprayed on epoxy coating. I am meeting with the company rep tomorrow. I will ask him if his product can be used on exterior furniture. I will add a post after that meeting.
MNsawyergp is offline   Reply With Quote
Old 04-08-2012, 11:54 AM   #3
joed's Avatar
Rewards Points: 11,576
You can get a marine varnish with UV in it. That would be your best protection. Don't forget the bottoms of the legs. However I would not expect too much from any indoor wooden table outside. A covered porch would be much better than letting it get rained and snowed upon.
Old 04-08-2012, 04:11 PM   #4
In a little over my head
Rewards Points: 706
In my experience with Adirondack chairs of various wood, the problem is "leaks" in the varnish. IOW, you can varnish the whole table, but moisture will find it's way in around joints, fasteners, end grain, etc. Make sure you seal the bottom and crevices, too. If the table is strong and solid, it'll probably last several+ years outside with a good coat of spar varnish or exterior paint. After all, there are plenty of houses with 50 year old pine siding that are still doing fine. Just keep them painted.
ratherbefishing is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Selling old deck wood? snosurfa7 Building & Construction 7 11-07-2011 02:32 PM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 04:04 PM
Any wood prep product for cracks in deck wood? FrankL Painting 1 06-11-2010 12:20 PM
