Can A 2.8 GPM Pressure Washer Power A Water Broom? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 08:12 PM   #1
Question
Can a 2.8 GPM Pressure Washer power a water broom?
is 2.8 gpm on a pressure washer (3400 psi) too "slow" to power a water broom?
What do you need to be able to use one to clean a driveway?
Thanks.
Learning2Diy is offline   Reply With Quote
Old 07-23-2012, 08:27 PM   #2
jschaben
Rewards Points: 502
Thanks.
I just did a little research on them, your question kinda piqued my interest in the things also. Here's a website
http://www.pressurewashersdirect.com...922/p1646.html
Interestingly, none I looked at talked about a GPM requirement, just PSI and from the looks of it you could drive up to a 4 head broom with your washer. But, I have a feeling you would have better luck with a 3 head given only 2.8GPM. Click on the specs tab and the FAQ tab.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Tags
gpm , pressure-washer
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
