Cable Cord Hole Too Big. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 10:42 PM   #1
cable cord hole too big.
this will probably be a easy question for most of you, but i am stumped. years ago when cable outlet was added to living room wall (before i bought this house) the hole thru which the cable would connect is about 1/4 inch too big and the slightest touch causes it to fall away from the wall. how can i make the hole tight enough to hold the cable in place? keep it simple pls, i am a 67 year old grandmother just trying to make what i think is probably a simple fix when given the right directions
lindah67 is offline   Reply With Quote
Old 07-09-2013, 05:41 AM   #2
I am not sure that I understand the meaning of "fall away from the wall", but it may not matter.
If you are simply trying to seal the gap between wallboard and the cable wire, and your priority is to keep it simple, try some caulk or silicone.
oberkc is offline   Reply With Quote
Old 07-09-2013, 06:01 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
Double sided tape is a silver bullet for little issues like that.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-09-2013, 06:55 PM   #4
Household Handyman
Rewards Points: 1,408
You did not state as to whether the cable came in through the floor or a wall. Either way I would suggest buying a small (about 3-4oz) tube of silicone for this. Place the cable where you would like it to be, with enough slack out of the hole if necessary. Maybe tape the cable to a wall to keep it from backing up. Put the silicone around the cable at the hole and allow maybe a full day for it to dry. I'm betting the cable will not be "fall away from the wall" anymore.
I need to test a cable for a kitchen range justplumducky Electrical 4 10-21-2012 11:23 PM
Armored cable shell as conduit? sixspeed Electrical 13 10-18-2012 03:45 PM
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 08:15 AM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 05:55 PM
