Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-04-2010, 10:11 PM   #1
cabinet screw question HELP
I have a cabinet its made out of what i call that particle board the screw ripped out of the particle board and now the hole is to big to put back in how can i re fill the hole and screw the screw back in
ckr31 is offline   Reply With Quote
Old 10-04-2010, 10:35 PM   #2
Assuming you are attaching the cabinet to a wall with wood studs... I would pre-drill another hole (a smaller size then the screw) an inch or so above the busted out hole. Then screw back into the stud again. You can probably find some calk or wood filler that would match or could be painted to the necessary color.
I would not recommend filling the hold and putting another screw through the same spot.
flipjarg is offline   Reply With Quote
Old 10-05-2010, 01:21 PM   #3
Stuck in the 70's
Blondesense's Avatar
You can simply use wooden matchsticks or toothpicks, dip them in white glue, stick them in the hole and break them off flush with the surface. Then install your screw and give it plenty of time to dry.
This is good for lightweight uses, hinges etc., but I wouldn't rely on it to hold a lot of weight as Flipjarg mentioned, especially in particle board.
Old 10-05-2010, 06:26 PM   #4
Cut a 1x4 piece of pine the width of the cabinet interior. Glue it over the particle board. Screw through the 1x4 into the stud.
Expecting a screw in particle board to hold a cabinet full of anything is wishful thinking.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Gary in WA (10-06-2010)
Stuck Screw IceTreay General Discussion 11 09-09-2010 02:56 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General Discussion 7 12-25-2009 08:47 PM
Did I screw up? .....Under cabinet light installation. Don't want a fire hazard! jws3 Electrical 21 08-31-2009 03:14 AM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
