-   -   cabinet screw question HELP (http://www.diychatroom.com/f2/cabinet-screw-question-help-83080/)
ckr31 10-04-2010 09:11 PM
I have a cabinet its made out of what i call that particle board the screw ripped out of the particle board and now the hole is to big to put back in how can i re fill the hole and screw the screw back in
flipjarg 10-04-2010 09:35 PM
Assuming you are attaching the cabinet to a wall with wood studs... I would pre-drill another hole (a smaller size then the screw) an inch or so above the busted out hole. Then screw back into the stud again. You can probably find some calk or wood filler that would match or could be painted to the necessary color.
I would not recommend filling the hold and putting another screw through the same spot.
Blondesense 10-05-2010 12:21 PM
You can simply use wooden matchsticks or toothpicks, dip them in white glue, stick them in the hole and break them off flush with the surface. Then install your screw and give it plenty of time to dry.
This is good for lightweight uses, hinges etc., but I wouldn't rely on it to hold a lot of weight as Flipjarg mentioned, especially in particle board.
Ron6519 10-05-2010 05:26 PM
Cut a 1x4 piece of pine the width of the cabinet interior. Glue it over the particle board. Screw through the 1x4 into the stud.
Expecting a screw in particle board to hold a cabinet full of anything is wishful thinking.
Ron
