Cabinet Hardware Question...... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-01-2014, 07:27 PM   #1
Rewards Points: 12
Cabinet hardware question......
I installed some cabinet pulls on some new cabinets last night. When you drill the holes on the of the cabinets some of the wood likes to splinter or crack on either side of where you're drilling. I was curious if theres some trick to prevent this from happening or if there is something you can put on the cabinets to cover up the splintering on the screw side. Any suggestions???? thanks!!!
hoffy85 is offline   Reply With Quote
Old 04-01-2014, 07:50 PM   #2
Civil Engineer
Rewards Points: 4,580
You need a really sharp drill to get it right. I like to use special wood drills with a sharp tip, not the twist drills used for metal. I have some German woodworker drills that work really nicely, no splinters, no chipping.
Old 04-01-2014, 08:00 PM   #3
Rewards Points: 5,974
Go slow the instant you see the bit starting to come thru STOP pull the bit out and come around and start drilling in the other direction.
The Following User Says Thank You to ToolSeeker For This Useful Post:
r0ckstarr (04-01-2014)
Old 04-01-2014, 09:12 PM   #4
MT Stringer's Avatar
Rewards Points: 240
Put a piece on the back so you can drill into it also and not splinter the back side.
MT Stringer is offline   Reply With Quote
The Following 2 Users Say Thank You to MT Stringer For This Useful Post:
ddawg16 (04-02-2014), r0ckstarr (04-01-2014)
Old 04-02-2014, 01:49 PM   #5
Rewards Points: 12
is there anything I can put on the backside to cover the splintering. Maybe something like a washer or something?
Old 04-02-2014, 02:19 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
maybe some wood filler
I like the ones that are fast drying-15 min.
Robpo is offline   Reply With Quote
Old 04-02-2014, 10:40 PM   #7
Msradell's Avatar
Rewards Points: 132
A washer would be fine, just use one to match the screw, SS or brass.
Msradell is offline   Reply With Quote
Cabinet hanging hardware Alan Carpentry 11 11-19-2013 09:15 AM
Cabinet configuration question jclee Remodeling 4 03-31-2013 09:00 PM
cabinet hardware johnnyquest1426 General DIY Discussions 2 02-04-2012 09:01 AM
Cabinet Hinge Question Brian More Carpentry 2 10-20-2010 05:54 PM
cabinet screw question HELP ckr31 General DIY Discussions 3 10-05-2010 06:26 PM
