Cabinet Hardware (pulls) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 12:18 PM   #1
cabinet hardware (pulls)
I am difficulty locating cabinet pulls ( size: 3.25 ) to replace my old, outdated ones. The cabinets are in good shape and don't require
refinishing. Any ideas where I can purchase cabinet pulls with this size?
Thank You!
bigdib is offline   Reply With Quote
Old 12-31-2011, 12:50 PM   #2
Ironlight's Avatar
Thank You!
Most dedicated online sources allow you to filter/sort by center-to-center size:
http://www.knobsandhardware.com/325i...a01000090.html
That size is definitely going out of vogue. The selection for 3.5" pulls has also dropped as it seems everyone has moved to 3".
Ironlight is offline   Reply With Quote
Old 12-31-2011, 01:06 PM   #3
Rewards Points: 14,026
Are you measuring from center of hole to center of hole?
As mentioned that's an odd ball size.
May be able to use a 3" of the whole elongated with a Dremel tool and a burr bit.
Another choice is to drill a new hole and mount the pull with a plate under it to hide the old hole. Patching will leave an unmatchable spot.
Old 01-01-2012, 11:03 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I got my drawer pulls off of ebay.
They were cheap, but they were cheap.
In other words the price was right, but a couple of them seemed to be bent or "seconds" and unusable, so if you go that route order a couple extra just in case.
Old 02-28-2014, 09:26 AM   #5
I am also having difficulty finding cabinet pulls in 3.25 center to center...anyone have any ideas..thanks!!
dahearn813 is offline   Reply With Quote
Old 02-28-2014, 09:34 AM   #6
Rewards Points: 144
http://www.amerockforless.com/ameroc...%2f2-in.-(89mm)
mako1 is offline   Reply With Quote
Old 02-28-2014, 03:20 PM   #7
Thanks for te link. The only ones in the size I needed were the exact ones I removed. However, I came across a site vandykesrestorer.com and found exactly what I needed. Purchased brushed nickel heavy stamped drawer pulls at the best price I have seen anywhere. Thanks again.
How to Install Cabinet Hardware Uniformly jegolopolli How To Guides 1 09-26-2010 10:14 PM
Fixing Cabinet Hardware Installed Uneven Nayr Carpentry 13 09-14-2010 08:13 AM
cabinet hardware satucker Carpentry 3 11-20-2009 07:54 PM
