Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-04-2012, 08:55 AM   #1
cabinet hardware
Our kitchen cabinets have no knobs on them and we are going to put some on. Is there a rule of thumb on were the height from the bottom of the cabinet to were the knob should be? I read on some that the height should be between 2.5" to 3" from the botom.
johnnyquest1426 is offline   Reply With Quote
Old 02-04-2012, 09:01 AM   #2
Disabled wood vet
titanoman's Avatar
cabinet hardware
Anywhere you want. Top, bottom or middle. That's the standard.
titanoman is offline   Reply With Quote
Old 02-04-2012, 09:01 AM   #3
cabinet hardware
That sounds fine. If there's a lots of them there's a simple plastic template you can buy at Lowes or HD in the knob area so everyone will end up in the exact same spot without even using a tape measure.
Works on handles to. There no very expancive at all.
Hardware for rotating cabinet DEET0607 Carpentry 5 01-09-2012 06:47 PM
Fixing Cabinet Hardware Installed Uneven Nayr Carpentry 13 09-14-2010 09:13 AM
cabinet hardware satucker Carpentry 3 11-20-2009 08:54 PM
