Cabin Walls Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 03:56 PM   #1
Cabin Walls Help
Hello, I'm new on here. Anyone have experience using OSB for walls? If so please talk to me about this. I have a small cabin and am trying to be economical in this venture. Thanks! e
EMARIE is offline   Reply With Quote
Old 07-25-2012, 05:02 PM   #2
DIY staff
Rewards Points: 7,174
I moved this for you---
Why not drywall---it has some fire resistance---It's cheaper than OSB and easier to cut and fix missed cuts---
Old 07-25-2012, 05:38 PM   #3
Rewards Points: 2,212
Are we talking interior or exterior?
mae-ling is offline   Reply With Quote
The Following 2 Users Say Thank You to mae-ling For This Useful Post:
oh'mike (07-25-2012), user1007 (07-25-2012)
Old 07-25-2012, 06:53 PM   #4
Too Short? Cut it Again!
If you were thinking of leaving OSB exposed as exterior walls you cannot as it will swell and fall apart if it gets wet. Same with plywood though.
If you do not need insulation, and if building permits allow, you could put up something like redwood plywood but it is hardly cheap.
If you are talking interior walls, I would go with drywall. Again, you could go with some sort of paneling I guess---subject to building codes.
Even though it is a cabin, you should add whatever wrap to the exterior and wall insulation you can manage to afford.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 09:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
