Originally Posted by sweetsue777
My husband and I are thinking of buying a house. We've only seen the outside, but we fell in love with the lot. Our realtor says the inside is "terrific," but the jury is still out until we see it obviously.
The house was built around 1960. We're going to look at it Friday. Can you guys tell me some specific things I should be on the lookout for when we're looking at the inside? We plan to get a home inspection, but I'd still like to know what to look for. .
Well, Where to begin? Maybe you should go to a book store and find something like a "Home Inspection for Dummies". (No sarcasm intended)
There are ALOT of things to look for. For starters:
Roof: How many layers, condition? (only way to tell is to get up on the roof and look) ridge-vent installed? Soffit venting or any kind of venting? etc...
Attic: Inspection can reveal the proper level of insulation, wall insulation, moisture of roof leaks, proper construction design, etc.
Electrical: kind of wiring, proper breaker box configuration, 200 amp? etc...
Heating system: Age of furnace, regular maintenance done?, efficiency rating? Cleaned?
Hot water tank: Age? condition?
Basement condition: Dry, moist, damp or even WET?!! (Run if wet).
Also examine the main carrying beam, joists, general structural design, any pest damage?
Plumbing: Condition? leaks? proper Capacity for home?
Sewage: Septic and leachfield age/condition? Concrete=best.
Paint/exterior: Condition? Maintained?
Chimneys: conditon? maintenance? Cleaned? Flashing condition?
Property drainage: Water run-off? Direction? Pooling? etc...
Gutters: Condition? No gutters? should have had gutters?
Bathrooms: Condition and age of: Toilet and floor around it. Bathtub and floor/walls around it. Condition of all plumbing fixtures?
Window and Doors: Condition/age? Energy efficient? Insulated? etc..
Foundation: Cracks, tilting, leaning??....Block wall, stains?, displacement? moisture on surface? etc...
Do you plan on expanding the home? addition, bathroom, etc....Does the property allow for it, will there be an issue with the town, neighbor, property lines? Do the home's current utilities allow for future expansion (Septic< etc...)
There is SO, So Much to consider and looke for. These are just the tip of the iceberg....
Your Home inspector should give you a full written report that should be very lengthy, possibly 50 pages +, discussing all of the above and much more.
Another thing, it's bricked all the way down to the ground, but I noticed it has vents around the bottom of the house and there's steps up to the front door. Does that mean it's not on a slab foundation? If so, what are the pros and cons of not having a house on a foundation?
Sounds like it could be a crawl space foundation?
Pros and cons are dependant on the area of the country and climate you live in.
Thanks for any advice you can offer! This will be the first home we've owned so I want to make sure we're making a good investment.
Hope this helps a little and Good luck on your quest....and your home inspection.
